View Single Post
Old 05-19-2014, 02:59 PM   #48
LoSt180
LoSt180's Avatar
Trader Rating: (18)
LoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond repute
Don't Ground the Oil Pressure Sending Unit
So, I have a 98 Kouki front clip and both pins of the oil pressure sending unit are used. The Z32 has the same sending unit and only uses one pin because there is an actual oil pressure gauge in the 300ZX gauge cluster.
Here's the wire colors on my 98 SR20DET
Yellow/Blue Stripe = Stock dummy light switch for gauge cluster
Yellow/Red Stripe = "Variable Ground" for the oil pressure Gauge
In other words, the sending unit grounds through the engine and there is no reason to ground one of the pins.
I've attached a pic of the sending unit and what the pins are for.
Now if someone could post pics, or instructions on what to trim to flip the gauge cover, that would be great.
LoSt180 is offline   Reply With Quote
