Old 11-10-2006, 10:27 AM   #1
OBEEWON
OBEEWON's Avatar
GT2871 USERS. SR motor
OK. Ive been doing alot of research lately and the results have been dissapointing to me. I have yet to find a dyno sheet of a .86 owner making 400 +whp, but I have seen a few .64 owners making such numbers. I was under the impression that you dont need cams on the .86 to reach 400, and that 460whp was possible. Even more disturbing was the fact that motors using .64 exhaust housings made more power on similar boost than motors on .86 GT2871's.
So, if you have a .86 or .64 A/R GT2871R please post a dyno sheet with mods, or your numbers, espescially for those in the 400whp range. If anyone can make sense of my findings please feel free to explain what you know.
OB
Old 11-10-2006, 10:51 AM   #2
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
You need cams to make 400.
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 11-10-2006, 11:00 AM   #3
IngS14
IngS14's Avatar
IngS14 is making a name for him/her selfIngS14 is making a name for him/her self
Send a message via AIM to IngS14
s14 on the dyno and spec
s14 zenki/s13 sr20det (stock internals)/GT2871R turbo/z32 mafs/550cc injectors/adjustable FPR/Fuel Pressure gauge/SAFC/wideband O2 on the dynojet putting down 325rwhp http://www.youtube.com/watch?v=pHllxSOwiXE
IngS14 is offline   Reply With Quote
Old 11-10-2006, 11:22 AM   #4
OBEEWON
OBEEWON's Avatar
Is that a .64, and do you have a ROM tune?
Old 11-10-2006, 11:42 AM   #5
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
What boost is that car running?
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 05-11-2013, 07:30 PM   #6
Nicholas6211
Nicholas6211 is an unknown quantity at this point
Nicholas6211 is offline   Reply With Quote
Old 05-11-2013, 07:34 PM   #7
AsleepAltima
AsleepAltima's Avatar
AsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura about
20-22 pounds. Ran great for a while
AsleepAltima is offline   Reply With Quote
Old 05-11-2013, 07:41 PM   #8
jamg
jamg is an unknown quantity at this point
7k miles aint bad for 20ish pounds.
how much power did you put down?
jamg is offline   Reply With Quote
Old 05-12-2013, 07:02 AM   #9
inopsey
inopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant future
7k miles is about 2-3 oil changes or a set of tires. a quality turbo should easily last longer than that.
inopsey is offline   Reply With Quote
Old 11-10-2006, 11:52 AM   #10
kensreliableb18b
kensreliableb18b's Avatar
Location: so cal - 626, 909, 562 and 949. 818 if i feel like running away
kensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nice
friends car: .64ar with 256/256 tomeis, escort manifold, boosted 1.5bar yielded 380whp/360tq. that should give you an idea. play with the cams. how much u wanna boost?
kensreliableb18b is offline   Reply With Quote
Old 11-10-2006, 11:54 AM   #11
usdm180sx
usdm180sx's Avatar
I just dyno'd mine. The car was tuned at HKS USA on 91 octane pump gas (since that's what it will be running most of the time) and at 16.9 lbs of boost (1.15 bar). They had to limit it there since the b/c started spiking. Here is the graph:
GT-RS is ismilar to 2871r .64. The motor has the following mods:
• S14 SR20DET
• Apex N1 exhaust
• CP Pistons (86.5mm Bore, 8.5:1 CR)
• Eagle H-Beam Rods
• Apex 1.1mm head gasket
• ARP head studs
• ARP exhaust manifold studs
• Blitz Stainless Steel downpipe
• Blitz SBC iColor Boost Controller (With wideband a/f and water temperature gauge)
• Exedy Hyper Single clutch
• Kazama Stainless Steel 80mm test pipe
• Greddy valve springs
• Greddy rocker arm stoppers
• Greddy intake manifold
• Greddy racing suction metal intake pipe
• Crower titanium valve retainers
• Greddy S14 hotpipe
• Greddy RSPL HG FMIC
• Megan Racing Turbo Extension
• HKS GT-RS turbo
• HKS 256/264 step 1 cams
• HKS stainless exhaust manifold
• HKS FCon VPro
• HKS Universal Power Flow filter
• HKS mechanical boost gauge
• HKS SSQV Blow off valve kit
• SARD adjustable fuel pressure regulator and fitting
• Tomei/NISMO 740cc injectors
• Tomei fuel pump
• Tomei 70mm Throttle Body
These turbos are designed for RESPONSE. Their efficiency levels off at around 19-20lbs. While it is possible to get 400 on these turbos I'd recommend a bigger turbo at lower boost.
-Norm!
Old 11-10-2006, 11:56 AM   #12
SoSideways
SoSideways's Avatar
Well he made 275 rwhp at 1 BAR, so probably like 1.4 BAR, or around 20psi?
Old 11-10-2006, 12:11 PM   #13
brainfood
brainfood's Avatar
Trader Rating: (18)
brainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond repute
Feedback Score: 18 reviews
Friends car with PFC when tuned made 375whp, stock bottom end. some headwork, 264 cams, tubular turbo mani, .86 housing, 15psi. I think it was on 100octane though. But still good power for very low boost.
Bryan Rogers
http://www.seriousbadass.com
brainfood is offline   Reply With Quote
Old 11-10-2006, 12:22 PM   #14
OBEEWON
OBEEWON's Avatar
Im I the only one with a .86?
Old 11-10-2006, 12:55 PM   #15
GSXRJJordan
GSXRJJordan's Avatar
cFinch used a .86 GT2871 on his 400whp Sr20 I think, try and dig up that thread. Everyone I know that has hit the 400 number has been using the .86 turbo, because the .64 levels off as you get close to redline. To add to that, every SINGLE person I know that has hit 400whp with a 2871 ends up getting a bigger turbo, like the GT3071 or T3/T4. It just doesnt pay off to run those types of boost numbers with that small a turbo.
Like USDM silvia said with the GT-RS (which is almost identical to the 2871 .64 BTW), those turbos are about hitting 350whp or so safely and with great response ~ if you want great response and 400whp, build the bottom end and put a lil n20 on it
Old 11-10-2006, 01:25 PM   #16
nonissan
nonissan is on a distinguished road
there's a thread on FA right now where 3 people came forward with 400ish whp on .64's. cams, obviously. stock exhaust mani on at least one.
not sure about the .86. i haven't paid much attention to that turbo because it is too much for what i want = 375ish.
i think matt vass was going either .86 or 3071, can't remember.
nonissan is offline   Reply With Quote
Old 11-10-2006, 01:40 PM   #17
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Most people opted for the smaller trim. I made 310whp @1.2 bar on 91 octane with a boost leak in my coupling that i didnt find till a week later. From my impression, it all depends on the tuning setup too. Ive seen people make 400 running power fcs. Check out Scott Avoys *enthalpy* and i know he got dyno sheets posted up in there that can give you ideas. Its possible to hit 400whp with it but not a whole lot can. If you want to make more power than that, id suggest going top mount and going T3 flanged turbo.
CLICK HERE!!!
Old 11-10-2006, 02:00 PM   #18
CarloSR
CarloSR is making a name for him/her selfCarloSR is making a name for him/her selfCarloSR is making a name for him/her self
http://forums2.freshalloy.com/showthread.php?t=158176
CarloSR is offline   Reply With Quote
Old 11-10-2006, 02:04 PM   #19
hybrid_eg
hybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the rough
with a .64, cams, injectors, enthalapy ECU, greddy intake man.. stock bottom.. although i had a big headgasket.. compression probably dropped to 8.1 i made 350whp at 19psi.. response on the car was great.. kicks in at very low RPM and felt great! excellent in my opinion for a daily driver..
hybrid_eg is offline   Reply With Quote
Old 11-10-2006, 02:47 PM   #20
brainfood
brainfood's Avatar
Trader Rating: (18)
I would have to agree. If you are going for 350-400whp run the .64 even if you dont quite hit your hp goal the response more than makes up for it. Responsive turbo cars are 1000times more fun to drive than laggy ones. If you are looking for over 400whp go with a top mount t3 flanged turbo or a gt30+
Bryan Rogers
Old 11-10-2006, 02:55 PM   #21
OBEEWON
OBEEWON's Avatar
True, but where does that leave the .86 2871?
Anyone want a free turbo? LOL
Old 03-13-2009, 08:22 AM   #22
91tofordee
91tofordee is an unknown quantity at this point
yes i will take it off your hands
91tofordee is offline   Reply With Quote
Old 11-10-2006, 02:26 PM   #23
OBEEWON
OBEEWON's Avatar
Most of the dyno sheets Ive been reading are from Enthalpy. Torque seems to be kinda low on both .86 or .64. I remember reading that 460hp was possible, but Iver never seen any such numbers. The closest Ive seen was 427hp on a S14 for sale here. He didnt list if he had cams or not. Just said Z32 MAF, JWT ECU, 740's.
Old 11-10-2006, 02:47 PM   #24
SoSideways
SoSideways's Avatar
Looks like the S3 cams work really well with the .64 A/R version of the GT2871R.
Old 11-23-2006, 02:31 PM   #25
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
That would be me. Just simply extrude honed, and swain coated. IMO the cost of what I did will put you slight above a cheap crack-a-fold, but at about half the cost of a really nice bottom mount tubular setup. Major advantage of mine: It works, it fits, and it will never crack.
Originally Posted by CarloSR
Thats me again
They work well with any response oriented engine. They are the most popular and powerful for a reason
Anywho, as some have said, it is achievable to reach 400 whp (and more) with a 2871r .64. I've got a stock bottom end redtop, running an 2871r .64 (extrude honed turbine side) and a stock (extruded and swaind) turbo manifold.
Simple parts that work with each other will always produce great results. All to often on these forums do we see mismatched cars that don't make the power they should (top end cams with small turbos, $1000 manifolds with $200 turbos etc etc)
My setup is pretty simple, and everything on the setup is designed to work in a way that creates maximum response and ultimate midrange torque. I take part in/compete in HPDE events, so I wasn't looking for some big power monster, as they are slow on the track, and not fun on the street. (Whats the point in roll racing from 60-120??) I'm a fan of being quick and having an all around animal of a car.
Mods:
Jim Wolf Technologies ECU
Cobra MAF
Mototron 60lbs Injectors
2871r .64 (extruded)
OEM turbo manifold (Extruded and swained)
Jim Wolf S3 Cams
Greddy o2 outlet
3" Downpipe
3" ExMag exhaust
Greddy Intake manifold.
Greddy FMIC setup.
Now this setup 'hopefully' will be making more power in the spring. I'm going to datalog my car, to send back out to JWT for a reflash and to have my water injection map tuned (for track days).
Here's the car:
Here's the Dyno Video (the speedo shot was done at 12 psi creeping to full....I will make another video of a speedo shot at a full 20 psi):
Youtube: http://www.youtube.com/watch?v=MDbB0b3xhHs
Download it here: http://govanman.com/ACEatthedyno.wmv
Here's the dyno:
@20 psi
Old 11-22-2006, 11:22 PM   #26
kove
kove is on the path to ruinkove is on the path to ruin
ill buy your .86 if you change your mind
kove is offline   Reply With Quote
Old 11-23-2006, 02:50 PM   #27
usdm180sx
usdm180sx's Avatar
Just wondering, how's your mileage? Did it decrease?
-Norm!
Old 11-23-2006, 04:15 PM   #28
fliprayzin240sx
With my 740cc injectors...i was getting 16-18mpg. More power = more gas suckage!!! Also depends on how boost happy you are. There were times i barely broke 200 miles to a tank.
CLICK HERE!!!
Old 11-23-2006, 05:05 PM   #29
codyace
codyace's Avatar
Trader Rating: (58)
I get 29-31 on the highway cruising.
Now, if I decided that I'm gonna raise hell, lets just it's comparable to a v8 hehe
Old 02-13-2011, 03:52 PM   #30
nismorb14
nismorb14's Avatar
nismorb14 is an unknown quantity at this point
hey man u have compressor adapters for a/c installs?ll i am interested whats the price shipped to tyler, tx.... 75701
nismorb14 is offline   Reply With Quote
