03-10-2013, 08:12 AM | #3001 |
03-11-2013, 02:33 PM | #3002 | |
Do you think I should keep my stock intake manifold or throw a freddy on it..... Mainly track duty but like to drive on the canyon's once in awhile... What do you think? i am still a little torn on this....
Turn and Burn! |
03-11-2013, 03:19 PM | #3003 | ||
03-11-2013, 03:29 PM | #3004 |
Sure, but with those cam profiles coupled with the manifold. I just wonder if it is worth it... I guess it still is.... I just hate lag above 4000 rpm.....
Turn and Burn! |
03-28-2013, 09:32 AM | #3005 |
maybe you guys can help me.
incite: JWT tuned sr20 with 2871r .64, external wastegate 10lbs spring, z32 maf, Greddy style intake, fuelrail, adjustable FPR, 500cc injectors, Apexi 1.1mm headgasket and rockerarm stoppers,.. stock block/internals. Intercooler exhaust etc. etc. Car drives awesome. AFR's are on point. Responsive and fast. Shit just doesnt break traction tho. Tire chirps/scratches is about all it gets. Granite its kinda grippy, with 245/45/17s in the rear at about -1 to -1.5 camber and 40-45psi. Just trying to get more of them torques, and just like everyone,. on a budget. Things I know, and questions I have. -I need to turn the boost up. -I need bigger injectors Q-Whats a safe number to turn it up to, given the 500ccs -I need jwt s3 cams -New diff (final gear) Q-I have a stock welded. 4.11 I believe. I know codyace has/had a 4.6 xterra diff. Which im sure would help. But I still do some street driving. Hows that ratio workout on the highway?....lol To sum it,...which angle should I approach to get best results for now,.. until i got the money to focus all efforts?...lol you dudes are dope
cONtRol FReAkS |
03-28-2013, 10:12 AM | #3007 |
i have no reason to believe its off,....but def something i could triple check
cONtRol FReAkS |
03-28-2013, 10:22 AM | #3008 |
You're running a very tall tire, with not much camber, that has something to do with it. Grip. You'll spin if you run a narrower tire or a 40 series sidewall. 245/45 is pretty tall on a 17. If you're on stock gearing it should be a 4.08 IIRC.
I bet you'd be safe at 16psi on 500cc, keep an eye on the wide band just to make sure. 740cc injectors will essentially get you whatever you want out of that turbo. Double check your timing, that's a possibility. Also <3
-Kyle |
03-28-2013, 10:59 AM | #3009 |
4.083..duuuh,.. i knew that! (good eye)
I figured the tires and alignment have alot to do with it,..lol I really like how this alignment feels tho, so prefer not to change that. Tires I def dnt have a problem playing with, I figured 245/45 would be a pretty safe grip/drift size tho. (spun these before) Got some smaller ones I could try? :P <3 back
cONtRol FReAkS |
03-29-2013, 09:57 PM | #3011 | |||
Trader Rating: (58)
Feedback Score: 58 reviews
With that said, aftermarket manifold ftw. While these turbos spool fast, the realistic powerband is 4500 to redline...in which the stock manifold DOES NOT help anything. Greddy/Freddy manifold FTW. It exemplifies that powerband best. Quote:
[QUOTE=conrad_s13.5;5200786] Q-I have a stock welded. 4.11 I believe. I know codyace has/had a 4.6 xterra diff. Which im sure would help. But I still do some street driving. Hows that ratio workout on the highway?....lol My car has gotten 30-32mpg countless times with the 4.6 final drive, when cruising at 60-70mph highway only. I don't speed much as the mpg is worth the difference. To me going 80mph isn't worth the saved nor gas time vs goign 70mph. I mean At that rate you're only really gaining 2-5 miles per hour gained, including cost.
03-29-2013, 10:31 PM | #3012 | |
For some reason the engine feels like it tightens up at 3500 (or whatever I'm doing at 75-80mph), The engine noise is less, it's smoother, and I really do get better mileage. Stock cams for right now, 550cc injectors, and basic tune,, yadda yadda. No don't have a GT2871, just a GT2860R, though upgrading it to a GTX2867 either this summer or when I finally get done overseas. |
03-30-2013, 11:47 AM | #3013 |
Trader Rating: (26)
Feedback Score: 26 reviews
My diff and final gear sucks :/
I'm at 3500rpm at only 70mph. I hate it. All this power and such a shitty gear ratio for it.
IG/TikTok-ThatS14_Z06guy |
03-30-2013, 11:51 AM | #3014 |
Recently put this baby on just waiting for a downpipe to be made, i got 550cc injectors, full fmic, rad, exedy stage 2 cluth, spec flywheel and a apexi power fc hoping to make around 300 high boost 240-260 low boost.
03-30-2013, 12:28 PM | #3015 | |
Trader Rating: (58)
Nice. It's fun coming home to car parts, trust me What do you have in it ratio wise?
04-02-2013, 10:38 AM | #3018 | |
Down man! See ya this weekend!
Guess i'll just up the psi in the tires and boost for now and see what happens!
cONtRol FReAkS |
04-02-2013, 03:04 PM | #3023 |
Lol I know it's a lot, but I have a very strong sr. just rebuilt it also. My friend runs almost the same setup, but only make 343whp at 18psi. We get our cars tuned by sammy tiger in ga he does a great job.
Sent from my myTouch_4G_Slide using Tapatalk 2 |
04-02-2013, 03:14 PM | #3025 | |
04-03-2013, 12:18 AM | #3027 |
well, I installed bc stage II cams on my car (gt2871r .64, 18psi, pfc) what afr should I shoot for at 8-12psi? at 18 I am getting 11.5-12.0:1... but I want to keep it at 14.7 from Load cells 1-10...
04-03-2013, 12:55 AM | #3028 |
Mesarina How did the car feel after you put the BC264's in? I have a brand new set but have yet to put them in. Right now the Car has a 2860R, but will be upgrading to the gtx2867 shortly. Do the cams add any more lag on the bottom end?
04-03-2013, 06:51 PM | #3029 |
I was skeptical too about the BC cams seen that some people don't recomend them, I got mine for $200 on ebay, the car feels a lot better, at 8-10psi the engine keeps reving (shifting at 7500rpms) you get a little more lag on the bottom end but not turbo lag, torque lag if you know what I mean... I came from v8s and always was bogging on the 180sx when trying to slide, but you get used to it... Im going to upload my inj, ign tables, and want to go to the dyno soon, but it already feels faster on the butt dyno... like 35whp
04-03-2013, 10:24 PM | #3030 | |
At what RPM do you feel it starts to catch up to the stockers? I know the top end on those is pretty good, but how much of a hit do you take on the bottom? Do you ever feel like the car is falling on it's face on the bottom end? BTW with the BC's how much vacuum are you pulling now at idle? |
