Old 01-22-2020, 12:10 PM   #3841
dreaMervaj
Trader Rating: (18)
dreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-known
Feedback Score: 18 reviews
Originally Posted by shaggyjake View Post
depends on where it's rubbing. rubbing the coil? it's not gonna fix it.
rubbing the edge of the fender? that'd fix (help) it.
that +15 is going to sit 8mm closer to the coil, and thus, 8mm more inboard from the edge of the fender. and the smaller tire size will obviously help.
Now, i can assume you are rubbing on both the fender edge and probably fender wells. I was running a 17x9 +35 (20mm spacer so +15 effective). with 3 degrees camber i was poking out quite a bit on the outside, but had ample room between the tire and coil. this was with a 255/40r17 tire.
that being said, 245/35 is not max tire on a 9.5 wheel.
Definitely not max tire and it doesn't look like I'll be able to fit a max tire on it. My 255/35 is actually rubbing the front wheel well. I think a hammer fixed it for now.. Lol!
Wish I could run 265/35 all around.
dreaMervaj is offline   Reply With Quote
Old 01-24-2020, 08:03 PM   #3842
Avayo
Avayo is an unknown quantity at this point
https://imgur.com/a/cbeug5i
Anyone have any info or guesses on wheel specs? I’ve got some 17x9 +22 wheels and I’m hoping for similar results. 255/40?
Thanks guys
Avayo is offline   Reply With Quote
Old 06-24-2020, 08:05 AM   #3843
shaggyjake
shaggyjake's Avatar
shaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choices
Comparison of two different sizes of the same tire.
Federal RS-RR
265/35r18 vs 275/35r18
most notable difference is tire height.
these tires are fitted on an enkei RS05RR 18x9.5 +22 wheel
265
275
265
275
265 mounted on front wheels, 275 mounted on back wheels.
EDIT: Front camber about -2.5+ degrees and rear is at 1.6-1.8.
Also noted is that these federals and also the RS-PRO run wide. These tires in a 275/35r18 measure about 11 inches, almost a 285/295. I am 100 percent certain if i fit 255/35r18 on the front and rear then I would be able to fit these with minimal pulling, but that's not max tire, is it?
shaggyjake is offline   Reply With Quote
Old 08-11-2020, 01:18 PM   #3844
AKsamuraiS14
AKsamuraiS14's Avatar
AKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond repute
Hey guys,
Will I have any issues running 17x9 +17 245/40 in the rear of my s13 with stock metal?
Thanks.
Aero-K Garage * Night Monkeys
IG - Shant_a_ganoosh
AKsamuraiS14 is offline   Reply With Quote
Old 08-15-2020, 04:03 PM   #3845
JesusFreakDrifter
JesusFreakDrifter's Avatar
JesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud of
Originally Posted by AKsamuraiS14 View Post
Hey guys,
Thanks.
should need some slight work. i had 255 on 17x10 +12 5zigen, and i had 2-2.5 inches of poke on stock fenders.
JesusFreakDrifter is offline   Reply With Quote
Old 05-25-2022, 12:01 PM   #3846
gixxerbob
gixxerbob is a well-known jackass
Im bringing this thread back from the dead cause it's just as helpful as ever
volk gt-c face2 18x10 +37. 285/35-18
stock camber, no pull, no roll.... yet
lm-gt3 18x10.5 +38 will be getting a 295
hopefully 1-2* of camber only requires a roll and minor pull
gixxerbob is offline   Reply With Quote
Old 05-25-2022, 01:15 PM   #3847
jr_ss
Hey, a man doing it right in here. Not maximum rubber for your camber gang setup! You have the meats…
Old 05-26-2022, 08:25 AM   #3848
silviaks2nr
silviaks2nr's Avatar
I finally went full retard with mine. The 295/30/18 R888R run a lot wider than the previous tires in the same size. wheel size is 18x11 +30
[IMG][/IMG]
'98 240sx 5spd
kouki 2jz t56 swap build
Old 05-26-2022, 08:57 AM   #3849
gixxerbob
im looking to run the r888r in 295 too.
how much pulling do you need to do?
Old 05-26-2022, 12:23 PM   #3850
silviaks2nr
They are pulled maybe 3/4", it's not too drastic. It does poke but with the ride height higher it really doesn't scrub.
'98 240sx 5spd
Old 05-29-2022, 03:04 PM   #3851
Agamemnon
Agamemnon's Avatar
[IMG][/IMG]
Your license plate says "Love to Jizz".
Awesome.
Old 05-29-2022, 03:13 PM   #3852
silviaks2nr
Awesome.
Certainly a double entendre. I had a cop pull up next to me at a light and rolled down his window and asked about it... he was dying laughing said there's no way the DMV let you have this.
'98 240sx 5spd
Old 05-29-2022, 07:19 PM   #3853
Agamemnon
Agamemnon's Avatar
I'll be completely honest, I know what the plate actually means. However my girl walked by my computer at the right moment and pointed it out.
After almost spitting out my whiskey I explained to her what it meant. Then followed by her response "yeah well I hope for his wife's sake he eats a lot of pineapple!"
Old 08-06-2022, 06:41 PM   #3854
sodel_s13
sodel_s13 is an unknown quantity at this point
Originally Posted by turtl631 View Post
Someone needs to post up Sasha's setup, here goes. His racecar was 18x9.5 RPF1 front with 275/35/18 RA1 and 18x10.5 rear with 305/35/18. Not sure on offsets, check ziptied if you really want to know. Worked well for his endurance racing purposes. I'm assuming since he recently parted the car out and was selling lots of damaged body parts that it got crashed.
Ok sorry to resurrect an OLD post, but anyone have info on the rear overfender size or make? Thanks!
sodel_s13 is offline   Reply With Quote
Old 08-07-2022, 07:44 AM   #3855
silviaks2nr
Looks like chargespeed
'98 240sx 5spd
Old 08-07-2022, 07:53 PM   #3856
sodel_s13
I wonder what size
Old 08-08-2022, 02:26 PM   #3857
Om1kron
Om1kron's Avatar
Originally Posted by sodel_s13 View Post
I wonder what size
chargespeed rear overs afaik only come in 50mm chief. I have them on my car.
Biggest tire I was able to fit on my front end was a 265/35/18 however it hit the firewall tub at full lock and started to damage the tires as well as rip my front bumper off. So I downsized to 245/35/18
Wayne Edwards
https://om1kron.blogspot.com
Old 08-08-2022, 03:22 PM   #3858
sodel_s13
I see, I see. Currently running 275/35/18 all around on 18x10.5 +15. It?s tight but my car is also not slammed. I saw Sasha?s car and his wheels set up is the same as mine.
I like the look of yours!
Old 06-17-2023, 12:15 PM   #3859
Snilssson
Snilssson is just really niceSnilssson is just really niceSnilssson is just really niceSnilssson is just really niceSnilssson is just really niceSnilssson is just really niceSnilssson is just really niceSnilssson is just really niceSnilssson is just really nice
Gentlemen, I am this close to buying a set of BBS LMs for my S13. They are 17x9 ET20 which is just what I have been looking for.
The car has coilovers and Z32 brakes. Rear fender is rolled but up front is untouched and even has brand new fender liners that I want to keep.
I am certain I want to go with 245/40 in the back but what would the maximum width be up front without compromising too much? 225/45 is the easy route but boring.
Snilssson is offline   Reply With Quote
Old 07-27-2023, 11:45 PM   #3860
Sumslapper
Sumslapper's Avatar
Sumslapper is an unknown quantity at this point
Been fancying to buy another S14 kouki or S13 vert.
17x9 +0 245/40/17
18x11 +19 295/30/18
Sumslapper is offline   Reply With Quote
Old 07-27-2023, 11:51 PM   #3861
Sumslapper
Sumslapper's Avatar
17x9 +20 255/40/17 square
Old 07-31-2023, 02:52 PM   #3862
kanyedian
kanyedian's Avatar
kanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nice
Cool
[img]https://live.staticflickr.com/293/18037497673_a13cc78733_b.jpg[//img]
That looks great! I'm shocked you fit such meaty goodness inside the fenders and still so low!
I have 245/40/18 on a 18x10 in the rear but I'd like to downsize to 225/40 and not sure what wheel width or offset to go to so that my same level of flushness is there.
Hmm got some thinking to doooo
kanyedian is offline   Reply With Quote
Old 09-03-2023, 06:29 PM   #3863
Sumslapper
Sumslapper's Avatar
I had a pretty aggressive pull all around. S14 can fit decent meat stock body, with the right offsets.
Old 10-21-2023, 02:33 PM   #3864
allntrlundrgrnd
allntrlundrgrnd's Avatar
There are some 17x8+5 fronts and 17x9+18 rears for sale near me. Anyone running sizes in that range? all stock metal s13
