Old 01-11-2023, 08:31 AM   #23821
splitfire
splitfire is an unknown quantity at this point
Originally Posted by Future240 View Post
Circling back to this.
FSM says to use oversized bearings if the crankshot measurements are off. Are the oversized bearings good enough or do they need to be matched like regular bearings?
If the crankshaft measurements are off, the crankshaft must be ground to match the oversized bearings. A competent machinist needed.
splitfire is offline   Reply With Quote
Old 01-26-2023, 12:40 AM   #23822
LordDalamer
LordDalamer is an unknown quantity at this point
Can someone please help me purchase a RH side JDM Kouki foglight cover?
LordDalamer is offline   Reply With Quote
Old 01-26-2023, 02:04 AM   #23823
AngusSinclair
AngusSinclair is an unknown quantity at this point
WTD S13 Coupe window visors please
AngusSinclair is offline   Reply With Quote
Old 01-26-2023, 04:40 AM   #23824
wezurii
wezurii is an unknown quantity at this point
Literally for sale brand new when you google s13 window visors
wezurii is offline   Reply With Quote
Old 01-26-2023, 05:00 AM   #23825
AngusSinclair
i should have said OEM ones sorry. they dont sell them for coupe anymore. was hoping someone on here may have had some
Old 01-26-2023, 09:24 AM   #23826
Agamemnon
Agamemnon's Avatar
A bit more info about which car this is for would be more helpful.
You should direct this to the Want to buy section rather than the small questions thread.
Old 01-26-2023, 09:14 PM   #23827
LordDalamer
97-98 S14 Kouki JDM Foglight trims
Old 01-26-2023, 11:21 PM   #23828
wezurii
There is a company who sells them brand new, not OEM ofc
HJC, HIC somehing like that
Old 01-27-2023, 07:16 AM   #23829
jr_ss
As mentioned, if your crank shaft is out of spec, it will need to be ground to ?true? it. When that happens, the machine shop should be measuring the necessary tolerances. Oversized bearings are a must (thicker backing plate) to correct the variance in those tolerances. An align bore should also be considered if upgrading hardware.
Old 01-27-2023, 07:19 AM   #23830
jr_ss
Dude thanks so much! This helps a lot. I got a good idea where to go from here.
I have a cargo net from an S14 if you want it. I just need to find it.
Old 01-27-2023, 12:15 PM   #23831
Agamemnon
Agamemnon's Avatar
Passenger Side #26152-80F00
https://www.ebay.com/itm/304723637983
Driver Side #26157-80F00
https://nismoparts.nissanusa.com/p/N...157-80F00.html
Old 01-27-2023, 02:48 PM   #23832
Agamemnon
Agamemnon's Avatar
Yeah, I'll take it. PM me some details when you get a chance.
Old 01-27-2023, 03:04 PM   #23833
jr_ss
There?s not much to pm you. I need to find it and the mushroom mounts for it. I?ll message you once it has been uncovered.
Old 01-27-2023, 09:45 PM   #23834
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
DOES ANYONE KNOW HOW TO GET A HOLD OF DRIFTFREAQ?!?!?
i have some dude wanting his motor mounts...
Old 01-31-2023, 01:00 PM   #23835
AKADriver
AKADriver's Avatar
I've got a high idle only when coming to a complete stop. Idle is set correctly with the TPS pulled, and is normal if I clutch in while coasting, but as soon as indicated speed drops to zero, it jumps up to around 250 rpm above where it should be for the engine temp.
It's an original 5 speed late '93 S13 KA. Mostly stock configuration except the PAIR system is removed.
I'll try unplugging the EGR/EVAP solenoid to see if that's what's doing it, but the behavior seems opposite of what I'd expect if that circuit is the culprit - the solenoid should be open pretty much only while coasting down and closed otherwise.
It's not a leaky brake booster or booster hose or check valve, nothing changes if I get on/off the brake pedal. It's entirely dependent on indicated speed. Power steering pressure sensor is installed and working. A/C is off (duh).
My only other thought is someone somehow put an auto trans ECU in it for some reason and it's idling up because it thinks it's in Drive? I never bothered to look at the ECU ID. I only took it out once, way back in 2017 when I bought the car. Or could any of the manual transmission gear sensors have anything to do with it? It's got the reverse, neutral, 4th, and 5th sensors, reverse sensor works, one of the four seems to have a slight oil leak and I wonder if it's flaky.
Old 02-05-2023, 10:29 AM   #23836
splitfire
What wiring gauge sizes are used in stock cars wiring?
Old 02-08-2023, 01:37 PM   #23837
EFITTZY
EFITTZY's Avatar
EFITTZY is making a name for him/her selfEFITTZY is making a name for him/her self
Most standard automobiles use an 18 gauge primary wire. Depending on your vehicle's original wiring, you might find that the typical wire gauge for the engine harness is 14-20 gauge. Copy and paste from this internet thing called Google
(づ。◕‿‿◕。)づ T E A M B L O O M
EFITTZY is offline   Reply With Quote
Old 02-09-2023, 03:15 AM   #23838
LordDalamer
appreciate the links. Ended up finding a full set for $60 on facebook.
Old 02-12-2023, 03:43 PM   #23839
Corbic
Corbic's Avatar
Part number for a RB20DET AC compressor pulley?
Old 02-12-2023, 07:20 PM   #23840
Agamemnon
Agamemnon's Avatar
There isn't one. It's part of the compressor itself. It may be able to separate it, but no unique part number.
Old 02-12-2023, 08:54 PM   #23841
Corbic
Corbic's Avatar
Sorry, not the actual compressor but the idler pulley that shares the aluminum bracket.
I think it's Dorman 89149. I ordered one and will report out.
Old 02-13-2023, 01:03 AM   #23842
Agamemnon
Agamemnon's Avatar
Originally Posted by corbic View Post
sorry, not the actual compressor but the idler pulley that shares the aluminum bracket.
I think it's dorman 89149. I ordered one and will report out.
#11925-42l02
Old 02-13-2023, 09:17 AM   #23843
Corbic
Corbic's Avatar
#11925-42l02
Lolwut
https://www.nissanpartsdeal.com/part...925-42l06.html
Old 02-14-2023, 07:28 AM   #23844
Thursday7
Thursday7's Avatar
On this topic, is this idler pulley for SR the same piece as for KA? The dude I had pick up an SR AC bracket for me lost the pulley and bolt like an idiot but I have like 3 KA brackets/pulleys.
Old 02-14-2023, 10:30 AM   #23845
Agamemnon
Agamemnon's Avatar
KA24D/E idler pulley #11925-77A10
SR20DET S13 idler pulley #11925-65F03
SR20DET S14 idler pulley #11925-65F01
Old 02-15-2023, 10:26 PM   #23846
Corbic
Corbic's Avatar
I can confirm the Dorman 89149 is correct for a RB20DET and RB25DET Neo.
Old 02-16-2023, 08:29 AM   #23847
Thursday7
Thursday7's Avatar
How did you backtrace a JDM part to a Dorman number? Can the same be done for an SR pulley? Sorry for the spoonfeed request lol but I guess I'm just impressed.
Old 02-16-2023, 07:02 PM   #23848
Corbic
Corbic's Avatar
Guessed. Lots of Nissan parts swap so I ordered a 300ZX idler pulley and it's the same sized, bearing and rib count.
SR? I'd guess a B13 SER Sentra would be the same.
RB starter, I back tracked the manufacturers part number. I think it's a Hitachi, turns out Mitsubishi Fork trucks use the EXACT SAME STARTER. Go from spending $500 to $65.
Old 02-19-2023, 05:17 PM   #23849
Agamemnon
Agamemnon's Avatar
https://page.auctions.yahoo.co.jp/jp...on/d1082362533
Has anyone tried these instead of the stock s-chassis door stopper? I see these all the time of Yahoo Japan Auctions and have been curious if this is a viable solution. My driver-side door squeals from stopper. I've checked around and Nissan discontinued them a bit ago.
Old 02-19-2023, 05:44 PM   #23850
jr_ss
I believe the R35 unit is compatible with the S14. I am not sure about the S13.
https://m.youtube.com/watch?v=VwKh3dFcv3Y
https://trust-kikaku.myshopify.com/p...15-663101841s1
