11-05-2004, 01:07 PM | #31 | |
11-05-2004, 01:27 PM | #32 |
that is what i thought. I've been using KA24E single wire sensors on my SR, i swapped the KA bung onto the stock SR elbow. It just takes an extra few minutes to heat up without the 3 wire heated ones and the sensors cost less.
11-05-2004, 03:16 PM | #33 |
Exactly. Either way, even though it takes longer to heat up the car takes a few minutes to warm up anyhow, and when the car is in warm up mode it operates closed-loop, meaning it ignores the o2 sensor anyhow
What does a generic 1 wire o2 cost? Like, $20? ~matt
it's not turbo lag...it's foreplay '01 Ford Excursion Limited. Powerstroke Diesel Coming in spring: ??? |
11-05-2004, 04:29 PM | #35 |
Read my above posts. Buy ANY o2 sensor that fits the threading/nut, splice away, you're done.
~matt
11-05-2004, 05:15 PM | #36 |
does anyone know the exact size of the nut on the Megan Racing outlet.. so i can go ahead and purchase the correct open ended wrench as i pick up an o2 sensor.. thanks
11-05-2004, 05:51 PM | #37 | |
msaskin - awesome info. I'm MUCH more enlightened now. I was of the understanding they operated more like a MAF, showing different voltages at different instances.
11-05-2004, 05:59 PM | #38 |
My Megan Racing O2 housing came with a threaded adapter for the o2 sensor. Since it was going on my CA and it has a fatty o2 sensor, I didn't need the reducer. I might still have it somewhere.
If you still need one, let me know. It's yours if I can find it. Joe
1991 240SX LE Fastback SOLD!! 1992 USDM OneVia CA18DET powered SOLD!! 1996 240SX Base Model Rockin' the 4 Lug 1995 240SX Base Model $400 project car... and it runs! |
11-06-2004, 09:06 AM | #39 | ||
0-1v, fixed A/F ratio scale. Here's the chart: Quote:
11-07-2004, 12:52 AM | #40 | ||
11-07-2004, 04:40 PM | #41 |
its irrelevant to this question.. but i tried taking out my stock outlet pipe today..omg.. it was such a Bitch.. and i couldnt even finish the job.. those bolts are so fkn rusted and a bitch to get off.. i dunno how u could do it..i stopped when i couldnt budge any of those bolts ontop of the outlet pipe connecting to the exhaust turbine.. anyone have any good tips on getting pesky exhaust bolts off like a piece of cake? cuz.. seriously.. i dont wanna dish out 80 bucks to have a muffler shop do it..
can u also tell me what ur choice of tools are when u took the pipe off.. i am so far tryna to use a open ended 13 metric.. but but with know luck.. haha good lucky anyhow tryna get exhaust bolts off with an open ended wrench... no extension.. damn.. im so tired.. |
11-07-2004, 07:16 PM | #42 | ||
Before you get frustrated because you think I'm giving you the Standard Form ID 10-T answer, think about this: When I worked at Nissan, a recall was issued on certain year V6 Xterras for exhaust manifold replacement. The recall job was said to be a 10 hour job (iirc), which means it'll take the average professional mechanic 10 working hours to complete the recall. After a few months of this, the guys at my shop started presoaking the exhaust manifold bolts with WD40, warming the engine to operating temperature, and applying some more after they shut it off. The bolts came off like melted butter, and they were able to do a 10-hour job in about 4 hours (even though they'd still get paid for 10.)
11-07-2004, 07:18 PM | #43 |
lol.. very interesting story man.. ill try presoaking them and running the engine and repeating the order.. u think liquid wrench or pb blaster will work up to par as well too?
11-08-2004, 02:57 PM | #45 |
PB blaster would work better...it's like the crazy crack-head brother of WD40
~matt
11-08-2004, 08:56 PM | #46 | |
92 FastBack - Project 98 SE - Daily Driver |
11-09-2004, 08:00 PM | #47 |
Ok. heres an update on my progress. So far i have actually installed the MR outlet pipe flawlessly. But the only problem i am facing right now is.. that the new o2 sensor that i have bought, the wires seem TOO short too reach the connector under the hood..
i purchased the Bosch #13276 200sx 1.8T o2 sensor (fatty) well i was wondering if i can just splice the wires off the stock o2 sensor(skinny) to the (fatty) o2 sensor. The Bosch sensor has a color diagram of (left to right) white,black,white While the stock sensor wires are (left to right) red,black,white.. OR white,black,red.. whichever side you consider "top" of the harness.. So my question is.. which wires should i splice them to? Im guessing black is ground on both the sensors..but can anyone clarifiy on this to how i should splice the old wires to the new so i can elongate the (fatty) sensor to connect to the harness? Sorry if i am not clear on explaing this.. I tried my best.. ill get some pictures up to show what i mean in a bit. |
11-09-2004, 08:26 PM | #48 |
Did the bosch sensor box (or paper with it) say which wire does what?
My suggestion is to just match the wires up. Wiring colors are [semi]standard for a reason. ~matt
11-09-2004, 08:50 PM | #49 | |
the harness with the red wire is the "skinny" o2 sensor from the stock o2 wiring.. https://home.comcast.net/~180sxdrifter/Picture_001.jpg https://home.comcast.net/~180sxdrifter/Picture_002.jpg thanks P.S. This might be a stupid question.. and you can flame me for this.. but how long can i run "safely" without an o2 sensor pluged in.. and if your answer is "not safe" plz help guide in the right direction to splicing this wires correctly for me to install.. thanks Last edited by -usmd-180sx; 11-09-2004 at 10:05 PM.. |
11-09-2004, 10:36 PM | #51 | |
11-10-2004, 05:07 AM | #52 | |
so it's just the wire length that's keeping you from plugging it in, or will it not plug in at all?
oh, and as far as how safe it is to run without one... it's not terribly unsafe, your gas mileage will just really suck. A buddy of mine ran without an 02 for... i dunno 9-10 months? It was installed in the car, just not wired in. That's what he got for ratfucking his wiring and trying to eliminate EVERYTHING! In the end, he hooked it up and got better gas mileage.
11-10-2004, 12:48 PM | #53 | |
11-10-2004, 02:16 PM | #54 |
That would work fine. Also, you can run indefinitely w/out the o2 sensor, the car will just get horrible gas mileage and probably run like hell.
~matt
11-10-2004, 03:30 PM | #55 |
It was plug and play on my red top.
The bosch sensor you got is the same on I'm using. plugged right into my o2 sensor harness. I guess my o2 wires were extended a little farther than yours. |
11-10-2004, 09:20 PM | #56 | |
~matt Yea, i figured that much.. my gas was fkn drained quicker than i expected going to school and back. Quote:
Well.. imma try splicing the old harness and wiring to the new o2 sensor and hopefully this is another lesson to be learned.. lol.. wish i didnt have to jerry rigg the damn thing |
11-18-2004, 02:05 PM | #57 | |
I mean, will my standard downpipe still fit if i get the megan racing o2 housing. |
11-18-2004, 05:03 PM | #58 |
Ok. For most universal type O2 sensor Black is usually the SIGNAL wire.
As for the other two, it doesn't make a huge difference where they go. Because your heater has no polarity, they can go on either side. The heater has a a resistor, once voltage is applied it will heat up the o2 sensor so it can fluctate and go to "close loop" faster. |
08-15-2007, 10:11 AM | #60 | ||
Trader Rating: (40)
Feedback Score: 40 reviews
Sorry I know this thread is old but im faced with the situation of megan racing o2 elbow with skinny o2 sensor. Second the above statement is false to anyone that reads this ion the future: If you really want to get down to teh nitty grider be prepaired to do some research, I dont feel like going into a whoel big spill about it so if you want just read this thread thouroughly: http://www.sr20forum.com/240sx/12447...explained.html ***note all o2 sensors are NOT created equally, this goes for non-wide band o2 also, it really boils down to what you ECU is refferenced for (Zirconia vs Titanis), DONT ever trust the ECU or harness that comes with your swap unless you actually got a complete front cut unmolested clip becasue ECU and harnesses get passsed around like dirty whores, thats word to the wise. On page 4 of the link you will find a sure fire way to tell what o2 sensor your ECU requies, hope this helps. I'll quote myself here anyways: Quote:
AND BY THE WAY DOES ANYONE KNOW IF MEGAN SELLS THE SKINNY O2 SENSOR ADAPATOR? |
