12-20-2006, 04:33 PM | #1 |
Banned from the Marketplace
KA24E auto shutting off on freeway
so i was on the freeway going to the dealership in my auto ka24e s13. cruising at about 2500 rpm and it seems like it jumps out of gear in and auto.. rpm jumps up and down rapidly from 2500 to 4000 and in between a few times then to 0 then i roll for 2 seconds and then it starts right back up like nothing happened.
then just now busting a U and it does it again but not as much plus when parking it feels weak. any ideas?. basic info 1990 s13 auto ka24e 141k miles completely stock.. |
12-20-2006, 04:37 PM | #2 |
mebbe your fuel pump is going out? i had a honda that when the fuel was low it would do that. and in u turns it would almost shut off then roll.... and then go again.
1990 240sx s13 ka24e OHHH YA!!! In the process of rebuilding 2002 F.o.r.d. Focus SVT All-Weather package, Steeda STS, Cool flow, borla catback, 3" ss dowmpipe, H&R cup kit, Front upper and rear upper Focus sport strutbars Focussport 9 mm wires, Denso iridium plugs, |
12-21-2006, 12:10 AM | #4 | |
Your problem could be due to one thing or a combination of things....a torque converter going bad...bad tranny sensor, bad tranny control unit..it's an auto remember....could also be due to a short in your engine wiring harness, etc., etc. etc. Only way to know for sure is start with the BASICS. #1). Is the Check Engine Light on?? If so, pull the Diagnostic code. This will entail either buying a Factory Service Manual, (FSM) for your model year car or downloading one from here on Zilvia.Net....you'll have to use the SEARCH function here to find the link. If the Check Engine light is NOT on, and there are NO Diagnostic Trouble Codes listed on your ECU, then you're gonna have to do it the HARD way....troubleshoot using your Factory Service Manual following the listed troubleshooting procedures in the FSM. The attached link, although not specific for Nissan 240SX's, will give you an idea as to what's involved with troubleshooting transmission problems. http://autorepair.about.com/cs/troub.../aa072702a.htm If you're not mechanically inclined or have friends that KNOW how to fix cars, then you might have to take it in to the stealership or your friendly knowledgeable neighborhood mechanic. Good luck...you're gonna need it....sounds like you've got a doozie on your hands!! ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies.... |
