10-24-2004, 07:34 PM | #1 |
Megan Racing Turbo Outlet -Elbow o2 question
Hey , I got the Megan racing turbo outlet and im not sure what o2 sensor im supposed to use with it . the stock one i guess is the skinny one and is way too small for it . the outlet looks liek it needs to use a bigger o2 sensor. I have a sr20det redtop , what o2 sensor should i use ? please help , thanks
10-24-2004, 07:36 PM | #2 |
I was told that the greddy one has the same size fitting but it comes with an adapter to be able to fit the skinny o2 sensors. please give me some info , all information is appreciated. thanks
10-24-2004, 07:54 PM | #3 |
wideband or egt?
10-24-2004, 08:05 PM | #5 |
right now the stock 02 on the stock turbo outlet is small and thin , the thread hole for the o2 sensor is bigger. Ive heard that there are two different o2's the skinny type and the bigger type , does anyone know what application the bigger o2 is used for ? thanks
10-26-2004, 08:15 AM | #6 |
rsxyz: After a quick inspection of my stock redtop turbo outlet, it appears that the stocker has a built-in 'adapter': the skinny 02 sensor threads into a big bolt (bung?) that threads directly into the outlet. This is the same set-up as the KA24DE.
Did you remove just the 02 sensor or the 02 sensor and the adapter? Todd |
10-26-2004, 08:29 AM | #7 |
I didnt know the stock outlet had the adapter in there because im still in the process of putting my motor into my car. The reason I was asking about it was because i ordered the Megan Racing outlet and my friend said the stock o2 was too small , but ill have a chance to look at the stock elbow today , thanks
10-26-2004, 12:39 PM | #8 |
The last time I bought an o2 sensor for the sr I got the one for a 87 - Nissan 300zx Turbo as listed on http://www.sr20det.nismo.org/srtech.htm , but it was too big for the stock pipe. It did have the same connector. That one might fit in yours.
11-02-2004, 06:04 PM | #9 |
Not a direct fit...
The skinny 02 sensor (redtop) is *not* a direct fit for the Megan Racing Turbo Outlet. Oddly, the fatty from the KA24DE fit right in!
MR does include a bolt that fits into the 02 sensor hole. I think their intention is that you tap it out to fit the 02 sensor. rsxyz: What was your pal's conclusion? Do you have the size/thread pitch for the skinny 02? sr240mike: was that 02 sensor the same size as the DEs? Todd |
11-02-2004, 06:28 PM | #10 | |
I was told that you can remove the bung from the stock 02 fitting and thread it into the elbow.
11-02-2004, 07:13 PM | #11 | |
11-02-2004, 07:59 PM | #12 | |
11-03-2004, 05:00 AM | #13 | |
You'll need to tap it out. I'll post specs when I do mine. Here's a few pics: Λ Visual of stock fitting on MR elbow. Sorry for the shit pictures. Λ Comparison of inlets. MR is much larger. Λ Side by side look. The size of the MR elbow is more evident when looked at from the o2 sensor side (I didn't get that pic b/c my camera is a POS). |
11-03-2004, 07:23 AM | #14 | |
well shit.
that sucks. I wonder if the greddy fitting would work, and if it could be ordered seperately...
11-03-2004, 09:56 AM | #16 | |
care to share the part number? also, how are you sure it's providing the same readings as your stock 02 sensor?
11-03-2004, 10:40 AM | #18 |
i bought one of those and didnt have a problem with mine, i have a s13 black top and i know the o2's are different from the red tops. so my input would be that the black top o2 fits in there without any modifications
11-03-2004, 03:05 PM | #19 |
I just tapped out the supplied MR cap bolt:
13/32 Drill Bit M12 x 1.5 tap I haven't put the car back together yet; I'll let you know how it goes tomorrow. Todd 90 Coupe 93 Coupe |
11-03-2004, 07:13 PM | #20 | |
11-03-2004, 07:37 PM | #21 |
I've been dealing with 02 sensors lately. I'm installing a new greddy 02 elbow on my red top. Here is what I have discovered:
87 300ZX 3.0L SOHC turbo 02 sensor skinny fits red top bosch premium oxygen sensor # 13385 does not plug in you need to cut off the harness and solder yours on 86 200SX 1.8L turbo 02 sensor fat type fits black top bosch premium oxygen sensor # 13276 plugs right in to factory harness I'm using the 13276 because my greddy elbow is missing the adapter. I'm still having issues with the elbow though. My s15 auto turbo has 2 studs on the bottom on of which is too long and is preventing the elbow from going on Gonna take the dremel to it in the morning to cut the stud down. |
11-03-2004, 08:55 PM | #22 | |
11-03-2004, 09:39 PM | #23 |
dude!
" bosch premium oxygen sensor # 13385 " is the part and part number that you can get from an auto parts store.. and it is the one that will fit the 1987 300zx and s13 redtop, little common sense man! lol oh and good info touring240 |
11-03-2004, 10:15 PM | #24 | |
11-04-2004, 09:46 AM | #25 |
One more thing:
I just finished putting the elbow back on the car. It's running great:
-- Spool starts a little earlier but the power still comes on at 3K. -- It's hitting 12+psi on my Autogage boost gauge a bit after 3K. -- Mods: JWT Pop charger, MR Elbow, MR downpipe, gutted stock cat (hi-flow 3" cat goes in this weekend), Apexi N1 catback One other thing that should be noted about this product: The skinny o2 sensor barely makes it into the main chamber of the outlet. On the stock outlet, it was fully in the chamber. Could this be a problem? Either way, I'm going to pull the bolt out and grind it down so the o2 will be in the flow. ----- 5-second Review: Cheap high-flowing elbow. No instructions. Requires some modification for o2 sensor. Good fitment in car. Chinese knock-off of GReedy unit. No divider wall. Decent quality. Welds are a bit sloppy. Unknown durability. Unknown flow capacity/dynamics. Price: built4race on ebay: $85 shipped. built4race is Megan Racing's ebay outlet. 3.9 stars out of 5 (good value) Todd Last edited by sciamop; 11-04-2004 at 10:48 AM.. Reason: oops, had a loose IC pipe |
11-04-2004, 07:13 PM | #26 | |
11-05-2004, 02:11 AM | #28 | |
11-05-2004, 09:51 AM | #29 | |
-- You make a hole in the MR bolt with the 13/32 drill bit. -- You put the M12 x 1.5 tap in the hole. -- You screw the tap into the hole and it makes threads in the hole. -- Screw the tap the way through the hole and unscrew it. -- Voila. You can now screw your o2 sensor into the hole. |
11-05-2004, 12:22 PM | #30 | ||
it's not turbo lag...it's foreplay '01 Ford Excursion Limited. Powerstroke Diesel Coming in spring: ??? |
