Archive and FAQs Archives and Frequently Asked Questions about the 240SX are in here. |
03-27-2002, 02:08 PM | #1 |
OMNOMNOMNOM
In order to convert kg/mm to lb/in do the following. Multiply the kg/mm amount by 56. So if you kg/mm spring rate is 6 kg/mm Front and 5 kg/mm Rear your lbs/in would be 336 lb/in Front and 280 lb/in Rear. Pretty Simple.
Below is a archive of Spring Rates for various stock and aftermarket springs for the s13 and s14. Enjoy, Please post any additions you may have to this list. Thanks! <hr color="#000000" size="1" width="100%" align="center"> s13 Spring Rates Stock '92 (from FSM) Front & Rear: 102 lb/in Front & Rear: 110 lb/in w/ HICAS Eibach ProKit Front: 114-200 lb/in | -1.8" Rear: 114-148 lb/in | 1.6" Eibach Sportlines Front: 137-230 lb/in | 2.2" Rear: 128-200 lb/in | 2.1" Suspension Techniques: 1.3" drop Front: 206 lb/in | 1.3" Rear: 155 lb/in | 1.3" 5Zigen R-Rate Front = 2.4-5.2 kg/mm | 134-291 lb/in | 1.3" Rear = 1.9-5.0 kg/mm | 106-280 lb/in | 1.1" Tein HA Front = 6 kg/mm | 336 lb/in Rear = 5 kg/mm | 280 lb/in Tein HE Front = 8 kg/mm | 448 lb/in Rear = 6 kg/mm | 336 lb/in Tein RA Front = 10 kg/mm | 559 lb/in Rear = 8 kg/mm | 448 lb/in Tein RE Front = 10 kg/mm | 559 lb/in Rear = 8 kg/mm | 448 lb/in Tein RS Front = 10 kg/mm | 559 lb/in Rear = 8 kg/mm | 448 lb/in Tein FLEX Front = 5 kg/mm | 280 lb/in Rear = 4 kg/mm | 224 lb/in Tein S.Tech Front = 3.2 kg/mm | 179 lb/in Rear = 2.9 kg/mm | 162 lb/in Zeal Function B-6 Sreet Spec: Front = 6 kg/mm | 336 lb/in Rear = 5 kg/mm | 280 lb/in Circuit Spec: Front = 8 kg/mm | 448 lb/in Rear = 7 kg/mm | 392 lb/in <hr color="#000000" size="1" width="100%" align="center"> s14 Spring Rates kg/mm DR21 Front = 4.8-3.0 kg/mm | 269-168 lb/in Rear = 4.0-2.8 kg/mm | 224-157 lb/in kg/mm DR Racing Front = 6.6-3.2 kg/mm | 370-179 lb/in Rear = 5.2-2.4 kg/mm | 291-134 lb/in RSR Hard Springs Front = 5.0 kg/mm | 280 lb/in Rear = 4.2 kg/mm | 235 lb/in TANABE SuperH Front = 3.0 kg/mm | 168 lb/in | -28mm Rear = 4.0 kg/mm | 224 lb/in | -9mm TRUST Sport Springs Front = 2.6 kg/mm | 146 lb/in | -25mm Rear = 2.6 kg/mm | 146 lb/in | -25mm HKS Super Sports Front = 4.14 kg/mm | 232 lb/in Rear = 3.46 kg/mm | 194 lb/in Tein HA kg/mm Front = 6 kg/mm | 336 lb/in Rear = 5 kg/mm | 280 lb/in Tein HE Front = 8 kg/mm | 448 lb/in Rear = 6 kg/mm | 336 lb/in Tein RA Front = 10 kg/mm | 559 lb/in Rear = 8 kg/mm | 448 lb/in Tein RE Front = 10 kg/mm | 559 lb/in Rear = 8 kg/mm | 448 lb/in Tein RS Front = 10 kg/mm | 559 lb/in Rear = 8 kg/mm | 448 lb/in Tein FLEX Front = 6 kg/mm | 336 lb/in Rear = 5 kg/mm | 280 lb/in Tein S.Tech Front = 4.8 kg/mm | 269 lb/in Rear = 4.4 kg/mm | 246 lb/in Zeal Function B-6 Sreet Spec: Front = 6 kg/mm | 336 lb/in Rear = 4 kg/mm | 224 lb/in Circuit Spec: Front = 8 kg/mm | 448 lb/in Rear = 6 kg/mm | 336 lb/in <hr color="#000000" size="1" width="100%" align="center"> |
06-13-2002, 03:32 AM | #4 |
This just in: <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
Whiteline Springs, parts 70055 and 70049 Front: 155Lbs/in | 35mm Back: 165Lbs/in | 40mm |
11-20-2002, 07:41 PM | #5 |
AutoX Junkie
S13
KGMM S21 Sport front: 3.2 kg/mm | 179.2 lb/in rear: 2.6 kg/mm | 145.6 lb/in KGMM S21 SuperSport front: 4.6 kg/mm | 257.6 lb/in rear: 3.8 kg/mm | 212.8 lb/in KGMM S21 Racing front: 6.6 kg/mm | 369.6 lb/in rear: 5.2 kg/mm | 291.2 lb/in |
04-15-2003, 12:52 PM | #8 |
Linear Springs for S13
Tokico Spring Rate - F : 3.0 kg/mm | 169 lbs/in Spring Rate - R : 2.7 kg/mm | 150 lbs/in Ride Height - F : -1.0 (expect -1 ~ 2 inch range) Ride Height - R : -1.0 (expect -1 ~ 2 inch range) RS-R Down Spring Rate - F : 3.0 kg/mm | 167 lbs/in Spring Rate - R : 3.0 kg/mm | 167 lbs/in Ride Height - F : -1.5 est. (95-98 240sx drop) Ride Height - R : -1.2 est. (95-98 240sx drop) Tein S-tech (I think the ones in the first post are incorrect - I got these from Tein's website) Spring Rate - F : 3.7 kg/mm | 207 lbs/in (MFG #'s) Spring Rate - R : 3.2 kg/mm | 179 lbs/in (MFG #'s) Ride Height - F : -1.5" (MFG #'s) Ride Height - R : -1.2" (MFG #'s) Progressive Springs for S13 H & R Sport Spring Rate - F : 2.0~2.08kg/mm | 112~116 lbs/in Spring Rate - R : 2.5~2.6kg/mm | 140~145 lbs/in Ride Height - F : -1.3" (MFG #'s) Ride Height - R : -1.3" (MFG #'s) |
06-02-2003, 01:59 PM | #9 |
S13
Nismo S-Tune (not height adjustable) _ _ _Front: 5.3 kg/mm | 296 lb/in _ _ _Rear: 3.9 kg/mm | 218.4 lb/in Nismo N1 _ _ _Front: 8/10/12 kg/mm | 448 - 672 lb/in _ _ _Rear: 8 kg/mm | 448 lb/in
I refuse to answer that question on the grounds that I don't know the answer. |
