12-15-2005, 05:12 PM | #1 |
Fix your stumbling idle in your KA
So for the past few months my car would idle normally until it came up to operating temps, then it would stumble, idle rough, and die, if the car was in neutral or i had the clutch in. I searched on here and couldn't really find anything that helped me out. I called a local shop , McKinney Motorsports and they gave me the best advice. Now through pictures and text I hope this helps anyone else out there struggling with the idle on their KA.
First the main cause of the idle issue is a dirty IAC valve. It's tucked under the intake manifold near the fire wall. Very hard to get at and expensive if you take it to a shop to get it fixed. But it doesn't need to be replaced, you can fix your nasty idle issues for less then $10! Here's how... Get a bottle of Intake cleaner, not carb cleaner, intake cleaner. See this hose: The bigger one on the right goes from your intake to the IAC valve. If you pull it off while your car is running it will die after a second or two. When your car is off, pull the hose off but leave it still on the nipple enough to seal. Go start your car and then come and using one hand pull the hose off and with the other hand keep your idle up by opening the throttle. With your now free hand get the bottle of intake cleaner and spray some of it into the IAC tube. The car will stumble but make sure to keep it from dieing or you will have to put the tube back on and start the process all over again. Repeat this process several times, I used about half the can. Re-install the tube and take the car for a drive! I drove for about 20 minutes and everything was fine. I did this about a month ago and still have no idle problems. Hope this helps, let me know if you need more instructions or pictures. Matt
I am PornstarMatt Team Hinga California |
12-15-2005, 05:28 PM | #2 |
wow thank you for that i have been having all sorts of issues with my idle like that, i will do this tonight. to clarify it is the larger hose on the right and you dont need to do anything with the smaller vaccum hose. So you take it off on the intake side and leave the hose still attached on the engine side while u spray down the hose? thanks
12-15-2005, 09:40 PM | #5 | |
so... after this cleaner goes through the aicv... it goes into your engine. I cant imagine its that bad for it though. |
12-16-2005, 11:04 AM | #7 | |
12-17-2005, 04:13 PM | #9 | |
12-17-2005, 04:59 PM | #10 |
i don't see why it wouldn't, although i never worked on an SOHC either.
the general principle is the same... spray it into your intake manifold. it's not just to clean out the iacv, but the manifold in general. |
12-17-2005, 11:51 PM | #12 |
I had the same problem on the KA24E, but i was silly and took off the whole thing without buying a gasket to replace it LOL. I found out however, this method would work and wished I did it.
On the SOHC- Locate the idle adjust screw Unscrew completely, be sure to apply some pressure on the screw while unscrewing, there's a spring, dont lose it. Spray your favorite cleaner in there Replace screw and adjust your idle back to normal WOOT ^_^ |
08-24-2006, 06:01 AM | #14 | |
_____________________________________________
RMS13 |
08-24-2006, 11:21 AM | #17 | |
Trader Rating: (31)
Feedback Score: 31 reviews
good thread, but it'll come back eventually, your best bet is to actually order the gasket from nissan, and take it off of your manifold, its not too hard just 4 bolts and a few plugs, then take some carb cleaner and spray it out throughly, and that'll fix it for longer, but remember that it'll come back after time, it's just like washing your car, it'll always get dirty again.
Slip Gypsies Blog Quote:
10-10-2006, 10:36 PM | #18 |
sorry to bring this up but a friend of mind gave me some completely fucked up info. instead of not using carb cleaner i did. and now the car wont start. anyway to flush this out.
10-10-2006, 11:42 PM | #19 | |
take your plugs out, clean them off and try again.
10-11-2006, 06:28 PM | #20 | |
so far this is what i have tried. 1.just try starting the car regularly 2.waiting a few hours to see if the carb cleaner dissolved (turned into days) 3.pulled the wires from the injectors, then tried starting the car 4.pulled the fuse for the fuel pump, took off gas cap and removed spark plugs, started the car, then put everything back. still no start. also tried to jump start my car thinking it could be the battery didnt work either. i still think the battery may be drained, ill have to check that out tomorrow. other than that all i hear is the starter and my exhaust making little "puff" noises. i want to throw my POS off a mountain. |
10-11-2006, 07:14 PM | #21 |
carb cleaner shouldn't fuck your shit up.
what exactly did you do? the only thing you have to worry about it keeping the car running while you do it, so it burns it off as you spray it. |
10-11-2006, 08:54 PM | #22 | |
10-11-2006, 09:26 PM | #23 |
damn that sucks.
i would pull off the whole intake manifold and clean it out real good. clean out the iacv as well. consider it a chance to really clean up your whole intake tract. taking it out isnt that bad if you have extension and swivel head sockets. you could even take this chance to replace all the rubber hoses, knock sensor, or even delete emissions... (ka-t.org has a write up on that iirc) the other option is to just let it air out and pray... XD at any rate, good luck! |
10-19-2006, 03:13 PM | #25 |
Fixed it
I drive an auto 240sx, and i was experiencing these EXACT same problems while the car was in Drive. If it was in Nuetral or park it would idle fine. But if i was at a stop light and had my foot on the brake, the car would stumble and go from 700-500 RPM very quickly and the entire car would shake it was hesitating so bad. I bought the intake cleaner after reading this post. The first time i sprayed some into the tube i used a little less than half the bottle. I didnt notice ANY difference, in fact, the problem seemed to be a little WORSE than before i put any in. I drove the car for about 1.5 weeks. Today i decided to put more in, and see if helped any. I did a second application, reducing the bottle to a little over 1/4 left. So far my idle is good, and hasnt been stumbling since i put it in. Hopefully my car stays like this definitely a good maintenance thing to do.
10-20-2006, 09:24 AM | #26 | |
edit: i have not tried cleaning out the iav valve like mentioned above
Project S14 Begins... |
01-11-2007, 06:28 AM | #28 | |
Don't mess with my monkey...he's loaded. |
01-11-2007, 07:57 AM | #29 | |
AFC #1
01-11-2007, 08:11 AM | #30 |
anyone know if this works for an SR?
www.illgarage.com |
