Originally Posted by twistedsymphony
Thanks again I'll give the window another look and see what's going on with the M6 nut....
As for the dash I'm trying to locate a good picture of the back side of an S14 dash so I know where all the clips are (the last thing I want to do is crack or otherwise damage the dash)... I'm still looking but if you know of a picture off hand a link would be appreciated.
FSM shows disassembly. There's no clips securing it, only the six M6 bolts, two behind the upper defrost grille, one behind the passenger side defrost grille, one behind the cluster, and one on each lower corner. After all the trim and parts are out only those bolts hold the actual dash in place.
