Originally Posted by Ghostdrifter
HI, I'm new to wheels fitment and I have a question. I'm running 18x10.5 +18 on the rear of a s13 hatch and my question is should I go with the 30mm rear overs or 50mm? The rear overs I'm goin with is Origin fender pull style. Also what tire size would you recommend?
What size tires are you planning on running and how much camber are you wanting to run?
If you want to run 295s and -1 deg camber then you should get some 50mm over fenders, haha.
If you want to run 245s and -3.5 deg camber then you can probably just do a mild pull.
