Originally Posted by FusionR240sx
mustang replica wheels on ebay.
$500 shipped and u can have like 17x10.5+26 rear and 17x9+27 front. like a 5mm for the rear and a 10-15mm spacer up front.
Ya I've checked those out before but there's no way a 10.5" rear wheel with 26mm offset is going to fit on an S13 with only rolled fender lips. Unless you stretched some skinny tire on there which is exactly the opposite of what this thread is all about. At 10.5" wide I'd need in the 50+ mm offset range as can be seen by Broadfields pics. His first set there were 10" wide and I believe 44mm offset.
Edit: I think I might have found my ideal wheel:
17x9 Rota DPT - Gold (5x100/114.3/e42/73) Wheeldude.com - Professional wheel dealer. #1 Rota Dealer.
17x9 42 mm offset, 5x 114mm available. they are selling for 850$ per set so they are a bit higher then I wanted to spend but they might be worth it. I should be able to get a 275mm tire on a 9" wheel just fine, right?
Fred
