Originally Posted by GSXRJJordan
No, I didn't quote your post, I quoted the one above it.
In response to your question, no the CAS does not send tach signals to the ECU, the ECU sends tach signals to the Tach. If you can't get a tach output from the Haltech, there are many tach adapters on the market you can use.
its not that i cant get an output from the haltech, its that the haltech is not seeing a tach signal. the yellow/red wire from pin 3 of the nissan conector runs to pin 18 on the haltech 36 pin conector. there is continuity between the two and the conections are fine. im wondering where the tach signal comes from that goes to the haltech. in other words where would the oem ecu pickup the tach signal from to show that the engine is moving?
