i forgot to mention that the fuel pump would click back off like normal sometimes. i think one of the relays in the driver side kick panel is causing it to click on and off. there is no leaks in the system. there are 3 relays that are on the fuse block on the driver side. one of the blue relays is keeps clicking on and off constantly. what relay is this? could this be a ignition relay of some sort? the fuel pump relay is not on the fuse block like the ones o mentioned.
