Originally Posted by misfitsfreak81
i will attempt to post a screen shot of the fuel map. the map is appears to be just fine. i was guessing that the 8.0 i was seeing on the wideband was due the the severe misfires that were happening on decel and that the ecu was just dumping fuel to stop the knock. this car ran fine for 2 weeks on the exact fuel map that it was running when it popped. the only variable was that the ignition was accidentaly locked at 15deg. that is the only change. so im relating the motor poping to the lock timing.
thanks for any more input
Misfires result in lean readings, typically.
Misfire causing car to run lean and smell like fuel? - evolutionm.net
Haltechs don't have knock control.
