Example of how you could drill and tap the modified brackets and insert threaded rod into it. Then simply use some aluminum or other material to make a "washer" to span the back of the vent opening. Finally some simple wing nuts and you can easily attach it all from the back. This will also help really suck the plate into the opening of the dash.
How much extra for you to machine me this extra little bit? I want these things to fit as tight as possible!
