Set the map to 15 degrees
Set the CAS to 15 degrees
if you want to start at 10 - 2 - 100 degrees go for it! There's no set way right?
The suggested manual method to override any specific EMS "Timing Lock" controls or function is to set the map manually to 15 degrees in the cells in the map where the Engine is scaling through or hunting through at idle or at the rpms ranges where you are checking the timing with the timing gun...
If you don't do this then you can still tune the car on the dyno but the timing map will probably be way off and hard to compare to other tuned cars etc, the timing advance may be 10 - 20 degrees too advanced or too retarded in the map during runs because it's just making power wherever the settings happen to be in the EMS map file and not scaled off base suggested BDTC with the CAS...
