09-22-2011, 02:12 PM
#1
Godspeed Project 90-96 Nissan 300ZX Z32 Type-RS Coilover Suspension!!!!
NISSAN 300ZX 90-96 TYPE-RS COILOVER SUSPENSION
PM ME for prices either pick up or shipped!
NISSAN 300ZX 90-96 (WILL FIT 2 AND 2+2 ALSO ) GODSPEED TYPE-RS 16 WAYS ADJUSTABLE COILOVER DAMPER KIT ( with pillow ball upper mounts )(2 FRONT STRUT , 2 REAR STRUT)
GODSPEED Coil-Over Dampers is the perfect enhancement to your track or street car. Featuring 16 Levels of damper force adjustment, full-height adjustment.
The damper can easily adjusted by turning the knob at the top of the damper. Turning the knob can simply change your daily driving or track day needs. The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can easily raise your car to oem height or lower your car for track performance.
The quality and durability of the GODSPEED Racing Damper kits are made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. we stand by our product with 1 YEAR warranty. (from date purchase. Must be installed by professional tuning shop)
Features:
- Spring Rates: 10kg Front and 8kg Rear
- 16 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
- All Hardware is Included
