We’ve got some great harnesses to show you. Probably a few of the most requested harnesses to be produced by Chase Bays, and here they are. There are so many features these have to offer, this kind of innovation and flexibility has never been done in our industry.
Even though the RB engines are remotely the same harness build, there is about 30 electrical variations. Variants include, coil packs or spark plug wires, coil igniter or integrated igniter, crank/cam sensor & pickups, different ECU’s, injectors, VTC valve, and a few others. We’ve done the research and become very familiar with these variants. So even if you’re not familiar with the electrical components, we are. The harness can plug into, basically anything. We use the same black 16pin connector near the ECU plugs on all of our harnesses. It has all the chassis inputs and outputs you need. The opposite side of this connector is what we adapt to YOUR chassis. When ordering this product on our website it will ask you all the info we need to know via drop down menu’s. This is all the innovation and flexibility mentioned above. Noone else knocks out 20 birds with 1 stone.
Chase Bays RB20DET Engine Harness
CM1 - $649.99
CM2 - $949.99
CM Mil Spec - $1,349.99
Chase Bays RB25DET Engine Harness
CM1 - $649.99
CM2 - $949.99
Chase Bays RB26DETT Engine Harness
CM1 - $699.99
CM2 - $999.99
CM Mil Spec - $1,399.99
PM for the lowest shipping prices. Find out more info on these harnesses by clicking the product names above
