View Single Post
Old 12-06-2011, 03:00 PM   #450
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
Originally Posted by Kwolfe View Post
What do you guys think of 17x9 +35 F and 17x10 +20 R on an s13 hatch, right now it's slammed on 16's so I'm sure I'll have to raise it up some. I'm looking for a pretty flush stance with maybe -2 or -3 camber. Will I need spacers? Will it fit in the first place? And what about tires? Right now my JIC's are as stiff as possible and I don't rub the 16's.
You'll need a 15mm spacer up front (you could run a 20mm with my tire suggestion), no spacer in the rear.
I'd recommend a 215/40 up front and a 235/40 out back.
If you only wanted to run a 15mm spacer over the 20mm up front go with a 215/45 but it will limit how low you can be because S13s are pretty limited for space and a 215/45 is just tall enough to keep you from really slamming it.
You may need a slight pull out back, but if you're going to run ~-3 camber you should be able to fit it.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
