View Single Post
Old 04-11-2014, 08:04 AM   #89
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
Originally Posted by 91 240 View Post
Time for a few updates. Holidays took a lot of time from me and I dont have a lot to show for it pic-wise, but i have knocked out some big items.
The last time i posted on it, it was over heating pretty quickly just from idling or cruising around the neighborhood. Come to find out, a modification i did to the water pump to plug the heater core outlets actually blocked flow through the thermostat. Sooo, very little coolant was flowing through the motor, definitely not enough. I pulled the water pump and thermostat off and drilled a hole inside the pump to allow water to flow around the thermostat.
I drove the car around 5-10 miles, nothing too much, and things seemed to be working better. I only had 1 fan running and the temps never got above 205*, i'll keep playing with this more as I start putting more consistent miles on it.
I pretty much finished my engine bay wire tuck. I condensed and relocated the pass side fuse box under the dash (pics of this coming) and moved the driver's side relay/fuse box under the wheel well, basically the same location. cleaned up the bundle of wires i had zip-tied around the driver's headlight (if you noticed in the video) and ran the wiring along the lower radiator core support. Only have one pic of the box location.
Then i was able to finally take care of something that i've been wanting to do for quite a while....i painted the hatch and quarter window areas with 2 coats of epoxy primer. Now i can put the quarter windows back on, get taillights mounted, relocate battery, mount the fuel door to the floor and then i can get the hatch back on. One step closer to being road worthy.
I came across a deal that i couldn't pass up. I found a brand new set of CTS-V Brembos at a killer price. Rotors from a Mistubishi Evo 8/9 and Mazworx brackets.
Pretty big size difference compared to the 30mm z32 calipers I had before(not my pic, I was working quick to get it done and didn't get a comparison pic)
Here's a wheel shot, i'll get better ones when I move it out of the garage again.
Finally, over the weekend i pulled the dash back out and have been working cleaning up all the wiring since everything works now, i need to make it a little more presentable. While i'm at it, i'm installing a new Viper alarm w/ remote start (Thanks Broadfield!).
i'm hoping to finish all the dash wiring this weekend and start piecing the interior back for good.
I have this alarm system, very pleased!!
supersayianjim is offline   Reply With Quote
