Originally Posted by e1_griego
Sounds like you changed something else.
Wastegate reference line is hooked up with no leaks?
If you remove the EBC from the equation does that fix it?
I have a feeling I know what it is but i'll have to check it later. I did change out my vacuum line from the EBC to wastegate because it was pinched (I thought this was the issue).
I'll recheck an update later. Thanks!
