CD009 Collins Adapter 2jzgtevvti
Hello, I am swapping a 2jzgtevvti into an s13, using a collins adapter plate and a ACT clutch. I read somewhere (and cannot find that source again) that the input shaft needed to be cut 1/4 of an inch in order to not bottom out on the crank. After beveling a small amount off the input shaft and attempting to mate the engine and trans, the bellhousing is roughly 1/2 inch away from being flush with the engine. I did make sure that the splines on the input shaft were correctly matched up with the clutch but, the trans wont go any further. My concern is if I cut more off the input shaft, I could cut too small and if I dont cut more and tighten it up with the bellhousing bolts, it could mess up my crank.
Any suggestions or input?
