1. Open the driver door.
2. Get in the car and shut the door.
3. Turn the ignition switch to the on position but do not start the car.
4. Open the driver door.
5. Press the "door ajar" switch in door frame 7 times.
6. Close the driver door.
7. Start the car.
This is the correct procedure for re-setting the airbag light. If it continues to blink after this, there's a problem with the crash sensor in the front of the car or perhaps the cluster has lost continuity with the circuit.
I'd recommend removing the airbags at this stage in the car's life. You don't want it exploding in your face if you hit a bump in the road or launch your car hard.
