Old 10-14-2023, 10:10 PM   #1
Harshened
Harshened is an unknown quantity at this point
Question Help? Any Ideas on whats goin on with my Z?
Maybe a timing issue? i havent got a clue, got the code P0340 and i knew that was a camshaft position sensor and i replaced it myself and the code went away then 20miles later the car died and took a phat min to crank back on and the same code p0340 came back up same sensor same side so i decided to take it into my local shop and they wayyyyy over charged me to replace both camshaft postion sensors and the pigtails to them and the SAME code is still there and its still starting the same as before.. i need help im scared to drive on it and its been sitting for almost a month because i havent got a clue on why its reading that code, not many people have had this happen and i cant find anything about it online.
Harshened is offline   Reply With Quote
Old 05-19-2024, 10:52 PM   #2
thoraharper
thoraharper is an unknown quantity at this point
I think you should inspect the wiring harness. Carefully examine the wiring harness that connects to the camshaft position sensor. Look for any signs of damage, such as frayed wires or corrosion. Ensure that the harness is properly connected and that there are no loose or damaged connections.
thoraharper is offline   Reply With Quote
