Old 02-03-2006, 11:37 AM   #1
pacefarm
pacefarm's Avatar
pacefarm is an unknown quantity at this point
Send a message via AIM to pacefarm
KA help with turbo id, and oil feed line size..
i got what i think is a t3/t04e turbine, already installed. also just got in the mail the jgs tools oil line kit. for some reason, the fitting feeding the turbine is too small.. this is the second line kit i've ordered, dont remember where i got the first one from. how can i figure out exactly what size turbo i got? also, what kinda fitting i need to feed it?? if anyone could point me in the right direction, i'd greatly appreciate it!
thanks a lot!
pacefarm is offline   Reply With Quote
Old 02-03-2006, 11:59 AM   #2
SpeedMonkeyInc
SpeedMonkeyInc's Avatar
SpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond repute
You need a bushing, I had to use one for my Garret T3/T4. Can't remember the for life of me what it was, I think it was a 1/4 to 1/8 inch.
SpeedMonkeyInc is offline   Reply With Quote
Old 02-03-2006, 12:31 PM   #3
pacefarm
pacefarm's Avatar
any idea what the thread might be on the turbo?
Old 02-03-2006, 12:34 PM   #4
SpeedMonkeyInc
NPT
Message length
Old 02-03-2006, 03:46 PM   #5
g6civcx
g6civcx's Avatar
Is your turbo clocked correctly?
Old 02-03-2006, 05:28 PM   #6
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Sorry to get off topic here, I can't help you with the line question.
Just wanted to say that, damn your turbine housing is close to your MBC. What happens when the engine rocks under accel? And what are you planning to do to stop the heat transfer to the MBC?
GL with your lines...
MELLO*SOS is offline   Reply With Quote
Old 02-03-2006, 11:43 PM   #7
pacefarm
pacefarm's Avatar
thats cause the car used to be an auto, and had a chubby brake booster that pushed the mc forward. i'm replacing that with a manual version, so that should help with the clearance issues.
as far as the lines go, ok, if i get the 1/4 to 1/8 bushing or adaptor, how would i fit an oil pressure restrictor on the housing then? these oil lines are really starting to get on my nerves.........
Old 02-04-2006, 01:04 AM   #8
SpeedMonkeyInc
Well the oil restrictor is usually 1/8 NPT fitting right? So screw that into the bushing, then your oil line AN to NPT fitting into the restrictor.
Old 02-04-2006, 09:08 AM   #9
g6civcx
g6civcx's Avatar
Your best bet is to contact Harp at Taka Motorsports. He does this stuff every day and can get you exactly the lines you need.
http://takamotorsports.com/
