Old 12-07-2005, 08:48 PM   #1
thejester03
thejester03 is an unknown quantity at this point
Send a message via AIM to thejester03
Ok, I give up!!!
So i have had my 93 coupe for about five months, I love it, BUT it idles like POOO!!!
I cant figure it out, it runs GREAT above about 2k, but idles rough, and dies on start up when its already warm, its like its getting too much fuel, and floods out, Im baffled, I have a new filter on a cold air, new 300zx fuel filter, Im stumped, the only codes im throwing is knock sensor, which Im guessing is from the rough idle. Ive cleaned the throttle body, visualy inspected vacuum lines, I just cant figure it out, please help me!!!!
Signature Exceeds Forum Limits
thejester03 is offline   Reply With Quote
Old 12-07-2005, 10:38 PM   #2
jeffg
jeffg is an unknown quantity at this point
What kind of intake? Do you have everything hooked up correctly? I know when I got my car they had the pair system hooked up post MAF, which is wrong, and the fittings where all leaking air.
Can you post a pic of your setup?
J
jeffg is offline   Reply With Quote
Old 12-08-2005, 12:15 PM   #3
DeBastaard
DeBastaard is an unknown quantity at this point
What engine are you using?
My CA18DET was idle'ing bad when I bought the car, and it got only worse, after trying out different AFM's etc. I still didn't have any solution
A Guy from dutch SX Owners Club told me to spray some Brakecleaner on the inlet manifold gaskets (With the engine running, doh ) and if there was an immediate effect on the RPM of the engine I could be sure it was the gaskets.
So I fixed those, and now it runs like sunshine
Maybe you should give it a try on your car?
DeBastaard is offline   Reply With Quote
Old 12-08-2005, 12:28 PM   #4
omgosh
omgosh is an unknown quantity at this point
Coolant temperature sensor perhaps?
omgosh is offline   Reply With Quote
Old 12-08-2005, 12:37 PM   #5
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
My suggestions...
Bad/sticking idle air control valve (I have the same problem right now). My car idles very rough, sounds like it misses, stumbles and even dies once in a while. Especially when coasting to a stoplight Other than at idle/decel though the engine runs like a champ! No CEL but I haven't checked codes recently.
Since you're getting code 34 bad KS, might want to test your Knock Sensor harness wiring to make sure you're not getting a short going from the ECU to the KS. I had that problem too a little while, which caused a big performance hit until higher RPMs and/or warm engine. Search my posts for keyword 'bog' to learn how to test your wiring and replace the KS with a dummy resistor for testing....
GL!
MELLO*SOS is offline   Reply With Quote
Old 12-08-2005, 08:41 PM   #6
thejester03
KADE motor, just FYI. Basiclay stock.
Awesome, thanks ALOT guys, great suggestions, how ever, that will have to be put on hold.....
I have come to the conclusion that curbs are a bad invention, just ask my broken Tension rod, Tension rod mount that is torn in half, twisted control arm, bent sway bar linkage, and i havent even gotten out the jack to inspect further, the 240 was doing AWESOME in the snow, but going around a corner at like 10mph, I hit a chunk of black ice and the front tires instantly had NO traction, I pumped the brakes turned the wheel back and forth, nothing, smashed into the curb at just the right angle to break everything, then got out and almost ate shit slipping on the ice, fuck me, I hate ice.
Old 12-08-2005, 08:52 PM   #7
dct223
dct223's Avatar
dct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nice
Send a message via AIM to dct223
my guess.. coolent temp sensor and the harness plug for it, get them both at nissan.
Sfourteen
dct223 is offline   Reply With Quote
Old 12-10-2005, 03:46 PM   #8
thejester03
Ok, quick Q, IF the TPS was out of agjustment, would it not confuse my ECU and give it too much fuel at idle? Just a guess. I'm not realy sure, also, can i Adjust the TPS by hand with a little trial and error?
Old 02-21-2006, 05:34 PM   #9
nsn240
nsn240's Avatar
nsn240 is on a distinguished road
Send a message via AIM to nsn240
Hate to bring back an old thread, but did you ever figure out this problem??
my sr is doing this exact same thing, and i cant figure it out
nsn240 is offline   Reply With Quote
