Old 05-31-2002, 03:45 PM   #1
KEIVmx
KEIVmx is an unknown quantity at this point
Before I buy a set of wheels, I want to make sure what size tires will actually fit.
I have 2 options:
1. Nismo GT2 17x7JJ
    Would 225 or 235's fit on these wheels?
2. BNR32 GT-R 16x8 (stock)
    What is the maximum width that can be fitted on these?
Thanks in advance for your time!
「僕は走&a mp;#12426;屋では&amp ;#12354;りませ&# 12435;。」
<<http://kein.5u.com>>
KEIVmx is offline   Reply With Quote
Old 05-31-2002, 04:22 PM   #2
smooth240
smooth240 is an unknown quantity at this point
Send a message via MSN to smooth240
I have 225's on 7" rims, no problems. That is about as wide as you can go safely and without losing sidewall stiffness.
With an 8" rim I wouldn't go above above a 245.
Hope that helps.
smooth240 is offline   Reply With Quote
Old 05-31-2002, 04:53 PM   #3
geeaj
geeaj is an unknown quantity at this point
Actually 215 would be the optimum size. You can do 225 but it isn't ideal. Alot of it depends on the tire itself. For example, Kumho 225s tend to run smaller then say Bridgestone REs..
Beware the fury of a silent man, be more cautious of his silent farts....
geeaj is offline   Reply With Quote
