Old 04-02-2006, 08:22 PM   #1
gumbygrys15
gumbygrys15 is an unknown quantity at this point
s14 rim width
Hi, I was wondering if have some help making a rim width decision. I have an 96 s14. Hear is the problem 17x8 or 17x9 front and rear. I want the same size rims front and back along with tires for equal balance. Normally I would go with the 17x9, but the 17x8 are 1.2 lbs lighter. I would be running 245 width tire and around 360-380hp. Also am I going to run into rubbing problems in the front. Thanks for your help.
gumbygrys15 is offline   Reply With Quote
Old 04-02-2006, 08:24 PM   #2
North240
North240's Avatar
North240 is an unknown quantity at this point
my vote is 17x9 but there is tons of info and feedback that can be found with a quick search.
ROUND 2
North240 is offline   Reply With Quote
Old 04-02-2006, 08:44 PM   #3
TheTimanator
TheTimanator's Avatar
first of all...1.2 lbs is a small sacrifice to get a wider wheel. Especially if you reach your power goals. Plus a 245 will fit better on a 9" wide rim and you can go wider later if you want where you would be limited with a skinnier rim.
As far as rubbing goes. You need to post the offset of the wheels since that will determine whether or not it's gonna fit.
Old 04-02-2006, 08:49 PM   #4
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
yah im looking at rims right now too, I really want a 17x9 but there is limited offering in 4 lug and im NOT spending money to convert to 5 lug, thats silly, although im prolly gonna get bashed, anyhow, I think im going to have to go 8 inch, I wanted to run a 245 but might just go with a 235, i also will have a hp range similar to yours. well see what happens. but yah if your only concerned with the wheight, then forget it, the extra inch is well worth it in my eyes, as long as you get a good offset.
mjjstang is offline   Reply With Quote
Old 04-02-2006, 09:02 PM   #5
nokeone
on strike three.
nokeone's Avatar
nokeone is making a name for him/her selfnokeone is making a name for him/her self
Send a message via AIM to nokeone Send a message via MSN to nokeone Send a message via Yahoo to nokeone
there are LOTS of 17x9 decent offset 4 lug wheels out there...you just have to do some hunting...
i would go 17x9 no question...you wont have fitment issues assuming you choose your offset correctly...anywhere in the +15 range and you will be fine...
panda; rockin your socks from the Bay to LA to SD, yay!
Pink GodziRa
nokeone is offline   Reply With Quote
Old 04-02-2006, 09:18 PM   #6
aznpoopy
aznpoopy's Avatar
17x9 +20mm 4x114.3 fn01r-c
splparts.com
Old 04-02-2006, 09:23 PM   #7
OMGWTFBBQ
OMGWTFBBQ's Avatar
OMGWTFBBQ is a glorious beacon of lightOMGWTFBBQ is a glorious beacon of lightOMGWTFBBQ is a glorious beacon of lightOMGWTFBBQ is a glorious beacon of lightOMGWTFBBQ is a glorious beacon of lightOMGWTFBBQ is a glorious beacon of lightOMGWTFBBQ is a glorious beacon of lightOMGWTFBBQ is a glorious beacon of lightOMGWTFBBQ is a glorious beacon of lightOMGWTFBBQ is a glorious beacon of lightOMGWTFBBQ is a glorious beacon of light
Send a message via AIM to OMGWTFBBQ
word
I have a set for sale right now
OMGWTFBBQ is offline   Reply With Quote
Old 04-02-2006, 09:58 PM   #8
mjjstang
wait wtf thats exactly what i want
i looked at slp they dont have 4x114.3 in 9 inch link please.
edit, how did i miss the little special section, too bad it requires rolling.
Old 04-02-2006, 10:13 PM   #9
Nizzan4u2nv
Nizzan4u2nv's Avatar
Nizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura about
Send a message via AIM to Nizzan4u2nv
Guess you didnt look hard enough.
http://www.splparts.com/Parts/Univer...en/default.htm
Nizzan4u2nv is offline   Reply With Quote
Old 04-02-2006, 11:06 PM   #10
nokeone
on strike three.
nokeone's Avatar
rolling?...no way....30 min, for all 4 corners, with a hammer to those inner fender lip things and it'll fit fine...add some minor camber and you'll be pimpin...(they just say rolling required to cover their asses since with totally stock fenders and no camber you'd rub a lil)
i ran 17x9 +9 offset on stock s13 fenders with just the lip hammered up...2 degrees camber (and i didn't even NEED that much, just wanted it)
Pink GodziRa
Old 04-03-2006, 12:13 AM   #11
mjjstang
yes but when s14db showed me this:
I immediately tried to find a local eastwood roller that might be circulating the Michigan streets, btw I just ordered these 17x9 +20 for s13 in hyper black, with some 245/40 MX's
Old 04-03-2006, 12:30 AM   #12
TheTimanator
with 245's you will at least need a roll. nokeone was probably running 215/45's or something. Obviously, the car you posted is on a shock/spring combo which is a toally different world then when your running coilovers as far as fitment goes....I swear I have seen pics with those size/offsets and 235's without a pull and they cleared but I could be wrong and I'm too tired to go look for it now
Old 04-03-2006, 12:34 AM   #13
Dousan_PG
Dousan_PG's Avatar
rolling fenders does not require some stupid fender roller
just like neokone said
hammer and some time
done
rolled
and way faster
and costs maybe 12 bucks for the mallet.
Aaron
Pink GodziRa
Old 04-03-2006, 12:36 AM   #14
nokeone
on strike three.
nokeone's Avatar
good call, i totally spaced on tire size...
you are correct..i run 215/45 up front and 225/45 rear so yeah it's a little easier i guess..
sorry about that...
buuuuut i still think it would be a very easy fit with minor effort on your part regarding the fenders...coilovers and a lil camber do wonders for fitment also..
yeah, hammered fenders, no pull required...
do it!..it's easy and you will love how it looks when your wheels fit nicely..
Pink GodziRa
Old 04-03-2006, 06:22 PM   #15
gumbygrys15
more info and questions
Does the extra inch of rim outway the advantage of the 1.2 lbs lighter wheel. The Offset I would run 17x8 30 or 35, 17x9 21 or 30. So I will need to buy wide body fender (20mm wider) or roll the fenders.
Old 04-03-2006, 06:49 PM   #16
mjjstang
it depends. thats a question that you will have to answer yourself, do you need beefy tires? what will you be doing with your car?
Old 04-03-2006, 09:28 PM   #17
TheTimanator
If you reach your power goal...I would say the 1.2 lbs is totally negliable. Even if you don't I'd still personally go with the 17x9's with the +21 offset. You shouldn't need to go with a wide body fender...S14 fenders are pretty big. Buythe 17x9 +21 with the 245's and if they don't clear...figure out how make them fit
Old 04-05-2006, 10:34 AM   #18
S13 Charlie
S13 Charlie's Avatar
S13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura about
Send a message via AIM to S13 Charlie
Do yourself a favor and go with the 17 x 9's. Are you running coilovers? If so, you'll need to get around a +20 or lower offset to use that size tire in the front. If you're making that kind of power, then 1.2 lbs per wheel is so negligible considering the wider track that the 9" wheel will give you. Put it this way, it's the difference between having 40 lbs/corner or 38.8 lbs/corner. And unless this is a dedicated track car, most of us would never be able to tell the difference.
S13 Charlie is offline   Reply With Quote
Old 04-05-2006, 11:08 AM   #19
DoriftoSlut
DoriftoSlut's Avatar
DoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to behold
Send a message via AIM to DoriftoSlut
Even if it IS a dedicated track car... with that power, the need for wider wheels heavily outweighs the weight savings. I mean.... if F1 cars (dedicated track cars in the utmost sense) were so concerned about this 1.2 lbs per corner of unsprung weight (it'd make a much larger difference on F1 car than a 240sx) then why wouldn't they go from a 13x15 to a 13x12 (a 1 inch decrease in wheel width is not going to produce the same weight savings as your commercially available 17x8/17x9s. Those are extremely heavy compared to an F1 wheel).
F1 car needs a 15 inch wide wheel. Your car needs a 10 inch wheel but for some reason you are limiting yourself to 8 or.. MAYBE 9. Go for 9 no questions asked. i would go 9 in front 10 in rear. Any day of the week.
Death Before Dishonor.
www.pinkgodzira.com
www.driftalliance.com
DoriftoSlut is offline   Reply With Quote
Old 04-06-2006, 02:50 AM   #20
s13coupedude
s13coupedude's Avatar
s13coupedude is an unknown quantity at this point
I'm having a horrible time finding any good 4 lug rims myself. The 5zigens are about the only ones I can find. Can anyoen direct me to a few more?
s13coupedude is offline   Reply With Quote
Old 04-06-2006, 04:20 AM   #21
!Zar!
!Zar!'s Avatar
Man, if you're only worried about 1.2 lbs...
Just urinate before you go for a drive. :P
Old 04-06-2006, 10:42 AM   #22
OptionZero
OptionZero's Avatar
SEARCH
Grenades GX01 or somethin (A Spec Products will supply you)
Mustang Cobra (ebay, $500 or less for a set of 17x9)
aaforementioned SPL Fns
Old 04-06-2006, 12:57 PM   #23
mikesim
mikesim's Avatar
mikesim is an unknown quantity at this point
Send a message via MSN to mikesim
i know people are going to knock the name, but you could get Motegi Touge's.
they have a variety of 4 lug sizes. 17X9 +24, 18x9 +12, and 18X10 +30. i don't know if you'll need rolling with the 18X9's.
also, consider what tires you'll be using. if you buy 245/40/17 falken zeix 512, or the FK452, you'd be better off buying a 17X8, taking the weight savings and cash savings and buying a better tire like the azenis 615 or advan 048 in 225/45/17
JDMOC||1989 Silvia K's
mikesim is offline   Reply With Quote
Old 04-06-2006, 01:06 PM   #24
DoriftoSlut
-10 points for that last post.
a.) Suggesting Motegi Touges
b.) For running a norrower rim and tyre
c.) Canada Fail.
Why not run 17x9 and a 245 RT615 (or imho Advan AD07)
www.pinkgodzira.com
Old 04-06-2006, 01:09 PM   #25
supportTHEezln
supportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud of
Send a message via AIM to supportTHEezln
I agree that if it's between a 9" and 8" get the 9", but you could still run a 245 on an 8" rim. And you find 4/5 lug combo rims all the time on yahoo auctions for very good prices/sizes/offsets. I'm actually thinking about buying a shitload and selling them here, haha.
supportTHEezln is offline   Reply With Quote
Old 04-06-2006, 01:30 PM   #26
i8yourfwd
i8yourfwd's Avatar
i8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfection
Send a message via AIM to i8yourfwd
Originally Posted by OptionZero
SEARCH
How heavy are those mustang wheels? And what's 4x114.3 converted to "standard" sizing?
http://jaythroughglass.blogspot.com
S13SilviaGirl: Mel are you that big?
i8yourfwd is offline   Reply With Quote
Old 04-06-2006, 01:53 PM   #27
Angel
Angel is making a name for him/her selfAngel is making a name for him/her selfAngel is making a name for him/her self
c.) Canada Fail.
He was suggesting that with the caveat that the poster use the money saved to run better rubber. Better rubber is far more important than just about any other factor when discussing wheel and tire setups. Still best to run the wider wheel and wider stickier tire.
S13 redtop 2871R.64 377 rwhp 322 rwtq
11.5 @ 117
Angel is offline   Reply With Quote
Old 04-06-2006, 02:42 PM   #28
aznpoopy
aznpoopy's Avatar
SEARCH
just another on the list
4x114.3 16x8+10mm rota grids
Old 04-06-2006, 03:05 PM   #29
OptionZero
OptionZero's Avatar
i'm fairly certain that a 225/45/17 RT-615 will outgrip f 245/45/17 Ziex 512...the ziex isn't a performance tire at all, it's for you to put on your mom's Accord to drive to the grocery store every day
Old 04-06-2006, 03:29 PM   #30
DoriftoSlut
Yeah but we're not discussing a 17x9 $750 a piece wheel vs. 17x8 $150 a piece. FN01RC 17x8 vs. 17x9 is barely any differece, if none at all.
www.pinkgodzira.com
