Old 04-13-2006, 08:25 PM   #1
Dante319
Dante319 is an unknown quantity at this point
KA Greddy Boost Gauge
Ok so I got an electronic boost gauge from greddy, 52mm, non peak hold, and I got the wiring done on it, but I dont have instructions on how to hook up the vacums for the sensor. I though I just needed to run a line from the intake manifold to it, but a friend is telling me that I need to use a Y, with one line coming from the intake manifold, and the other one teed off the fuel pressure regulator line, the both merge through the Y and then connect to the sensor. Is this the right procedure?
Thanks
I'm gonna show you that a mobile suit has its limits my friend, especially when you are up against the Red Comet
Dante319 is offline   Reply With Quote
Old 04-14-2006, 12:04 AM   #2
SpeedMonkeyInc
SpeedMonkeyInc's Avatar
SpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond repute
Just tee off a vac line any where on the manifold and send that to the gauge. Don't know what this merge stuff you are talking about is.
SpeedMonkeyInc is offline   Reply With Quote
Old 04-16-2006, 07:47 PM   #3
SR20d2fourT
SR20d2fourT's Avatar
SR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura about
I T'd mine off the FPR line and it reads fine. Do that.
My opinion gives me redboxes
SR20d2fourT is offline   Reply With Quote
Old 04-29-2006, 09:50 PM   #4
komedy
komedy is on the path to ruinkomedy is on the path to ruin
what does fpr stand for by the way?? ive search but can see, to find the answer?
komedy is offline   Reply With Quote
Old 04-29-2006, 10:09 PM   #5
SpeedMonkeyInc
Fuel pressure riser
Old 04-30-2006, 03:53 PM   #6
komedy
oh yeah lol, yup got mine hookes up to that too
Old 04-30-2006, 03:53 PM   #7
komedy
so its fuel pressure riser and not fuel pressure regulator?
Old 04-30-2006, 04:40 PM   #8
SR20d2fourT
Regulator*....
Old 05-01-2006, 09:28 PM   #9
NemeGuero
No more nissan.
NemeGuero's Avatar
Its regulator. and they say to use that vacuum source for the most accuracey..
but you can really just take vacuum from any nipple on the manifold. You will be hard pressed to notice much of a difference in the readings.
Old 05-01-2006, 11:31 PM   #10
komedy
does it matter if i tee it off closer to the trottle boddie or near the turbo after the blow off valve??
Old 05-01-2006, 11:35 PM   #11
NemeGuero
No more nissan.
NemeGuero's Avatar
You want it off the intake manifold.
Old 05-02-2006, 12:35 AM   #12
komedy
So Closes To The Intake Manifold?
Old 05-02-2006, 09:34 AM   #13
RSP13-Sideways
RSP13-Sideways's Avatar
RSP13-Sideways is making a name for him/her selfRSP13-Sideways is making a name for him/her selfRSP13-Sideways is making a name for him/her self
Send a message via AIM to RSP13-Sideways
Yes on the intake manifold or before the throttle body basically. You can T-off of any vacuum line but if you have an extra nipple, just go direct to the intake manifold.
- Jay
WTB: Nothing at the moment. LEWL
WTS: Everything sold, thanks folks!
RSP13-Sideways is offline   Reply With Quote
Old 05-02-2006, 02:58 PM   #14
komedy
yeah i see two nipples but there both used
Old 05-02-2006, 03:35 PM   #15
NemeGuero
No more nissan.
NemeGuero's Avatar
Then go buy a T available at any hardware store.
Cut an existing vacuum line, insert the T and go off the other end of the T to your boost gauge.
Done and done.
Make sure the fitment is tight or you'll get a vacuum leak.
