Old 05-01-2006, 06:54 PM   #1
240silvia
240silvia's Avatar
240silvia is an unknown quantity at this point
Send a message via AIM to 240silvia
Damn throttle body is sticking HELP!
Just like the title, my throttle body is sticking. I tried to wipe all of the gunk out from around the inside. Does anyone know what I could do to keep it from sticking? Thanks, Charles.
240silvia is offline   Reply With Quote
Old 05-01-2006, 07:45 PM   #2
mrmephistopheles
mrmephistopheles's Avatar
don't do naughty things with your throttle body.
Originally Posted by PHLIP
Old 05-01-2006, 09:08 PM   #3
krustindumm
krustindumm's Avatar
krustindumm is an unknown quantity at this point
Intake system cleaner. Unhook a vac line after the MAF, but right before the TB, and spray it in. Keep pulsing it to keep the engine barely running. I'd use a whole can.
Also check the cable.
ASE Master Technician
krustindumm is offline   Reply With Quote
Old 05-01-2006, 09:14 PM   #4
240silvia
240silvia's Avatar
i know it's not the cable, it's the TB. I'm turbo so I don't have a vaccumm line by the throttle body, just the IACV. So where should I inject the cleaner? I think I might try to loosen a hose clamp and slide the red tube from the cleaner inside the IC piping. We'll see, any more ideas???
Old 05-01-2006, 09:44 PM   #5
krustindumm
Slipping it in past the clamp will work. Just make sure you don't spray it on the MAF.
Old 05-01-2006, 10:21 PM   #6
240silvia
240silvia's Avatar
Well the maf is before the turbo, I was going to slip it in the coupler, so it would go into the intercooler piping right before the turbo.
Old 05-01-2006, 11:15 PM   #7
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Get a Carburator cleaner spray and spray the crap out of your throttlebody with it. Inside and outside. That should get most of that gunk off.
CLICK HERE!!!
