Old 05-04-2006, 07:43 PM   #1
RyanA96
RyanA96 is an unknown quantity at this point
Need Help Getting Speedometer to Work...already searched
Ok so heres the deal, i have a 93 240 with Redtop. The speedometer is a digital and worked before the swap. Now it will turn on but just read 0 all the time. I've narrowed down that its not the sensor itself because I checked the resistance and it went up and down with speed, so its not the sensor. I really think its just a wiring problem.
The 2 wires coming out of the vss are Green and Black. Now their are 5 plugs to choose from....
1) Yellow/blue and Black
2) Green/orange and Black
3) Green/white and Green/blue
4) Yellow/red and Black
5) Yellow/Blue and Yellow/black
I'm 90% certain its #5 because by looking up in the FSM it showed the 2 wires coming off of the HeadsUP Display unit going to the VSS as Y/L and Y/B. (the L in Y/Lis light blue, correct???).
I really didn't hook it up very good to this plug but it still didn't work. I'm thinking its either I didn't hook it up good enough or their is another gap in the wire somewhere between the plug and HUD display unit.
Before I dice up my harness even more, please help if you know how to figure this out....thanks
RyanA96 is offline   Reply With Quote
Old 05-05-2006, 10:31 AM   #2
g6civcx
g6civcx's Avatar
L = Blue. B = Black. LB = Light Blue.
Maybe your cluster is broken. HUDs do that sometimes.
Old 05-05-2006, 11:36 AM   #3
RyanA96
Nevermind problem fixed. It is the #5 plug. Hooked up green to Y/L and black to Y/B and it worked. Finally a SPEEDO YIPPPEEEE lol
