Old 06-11-2006, 02:18 PM   #1
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
alternator questions
testing a few things electrically and have a few questions...
battery no load = 12.4
battery under load = pretty much same
alternator under load (idle first minute of starting) = same as battery
is my alternator busted??
after a 15 mile drive now the battery reads the same as before i started it
sean350z is offline   Reply With Quote
Old 06-12-2006, 10:53 AM   #2
sean350z
sean350z's Avatar
i'm taking it off tonight and will be taking it to a bench tester tomorrow...
will an alternator from a sentra se-r (SR20DE) fit on my S15 motor?
Old 06-12-2006, 11:04 PM   #3
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
thats the same question i ask myself and others. i'm having the same problem too. its drianing my battery or could it be my grounding that is bad cause my starter grounding keeps poping off everything i put it back. it just died on me whn i was on the way ta work.
s13silvia123 is offline   Reply With Quote
Old 06-13-2006, 01:05 AM   #4
CaoBoY
CaoBoY is making a name for him/her selfCaoBoY is making a name for him/her self
bench test it yourself. start the car, pull the ground cable off your battery. if the car dies, your alternator's dead/dying. if it keeps running, then its doing its job and charging the battery. it will die almost immediately.
pulling outta the game:
http://www.zilvia.net/f/showthread.p...wpost&t=119867
parting out, just let me know.
CaoBoY is offline   Reply With Quote
Old 06-13-2006, 06:56 AM   #5
sean350z
sean350z's Avatar
well i didn't do the ground wire test ... here's a picture of the alternator to lead me to believe it's broken
the load tester will tell the truth today...
S15 part number 23100-85F10
Old 06-13-2006, 07:07 AM   #6
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
If you are not getting at least13+ volts out of the alt or at the batt WILE the car is on. It is not doing it's job.
NIK90s13 is offline   Reply With Quote
Old 06-13-2006, 07:17 AM   #7
sean350z
sean350z's Avatar
yep i def wasn't getting 13+ volts at the battery or alternator...i'm just getting load tested to make sure my wiring isn't bung....
Old 06-13-2006, 07:24 AM   #8
Inlandsilvia
Inlandsilvia's Avatar
Trader Rating: (25)
Inlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond repute
Feedback Score: 25 reviews
Send a message via AIM to Inlandsilvia
i had the same problem....swapped it out with a KA alt and it worked fine...only thing is change out the sr alt bracket for the ka and it will work. I have a S14 Kouki SR20DET and it works fine.
Inlandsilvia is offline   Reply With Quote
Old 06-13-2006, 07:27 AM   #9
sweet89s13
sweet89s13's Avatar
sweet89s13 has a spectacular aura aboutsweet89s13 has a spectacular aura aboutsweet89s13 has a spectacular aura aboutsweet89s13 has a spectacular aura aboutsweet89s13 has a spectacular aura aboutsweet89s13 has a spectacular aura about
after I relocated my battery to the hatch to make way for a front mount, my car hasent been keeping a charge either. My turbo timer and SAFC tell me the voltage is below 11, and this morning while the car was running it was at 10.8 and declined as the RPM's went up. Needless to say I got a ride into work this morning cause with my battery like that Im driving a life size remote control car. Dead battery, dead car. a real time battery meter is a really good idea, I never had a use for one but since I have had access to one, its nice to know whats going on.
The grounding lead to the alternator touched my turbo oil sending line and grounded out, was enough to cook some electrical tape, since then it hasent been the same. My wiring might be crapping out there too. Let us know how it goes
SHIFT_SLIDE
sweet89s13 is offline   Reply With Quote
Old 06-13-2006, 10:18 AM   #10
sean350z
sean350z's Avatar
Turns out NAPA says the alternator is dead....going to be hooking up a KA one tonight. I'm using the SR bracket but going to drill out the bottom mount hole on the KA so I can use the SR hardware.
