Old 08-27-2006, 06:02 PM   #1
Shells
Shells will become famous soon enoughShells will become famous soon enoughShells will become famous soon enoughShells will become famous soon enough
s14 Another window question. (1995)
Well, after searching and reading through the results, I'm still not sure, so any help would be appreciated. Here's the situation.
I bought the car and the windows didn't work. No big deal. I search around and learn that the amplifier is a common problem, so I buy one used on eBay. While I'm waiting for shipment to arrive, I pull the panels and discover the previous owner pulled the window motors. Those might be helpful. So, I bought some window motors from some guy on here. I installed them. Driver's side - great. Passenger side - ehh, worked off and on.
The passenger side has become the main problem now. It started out working most of the time, then somtimes, then rarely, now not at all. When I get the window up, it will roll down no problem. It has a problem with "up" though. I swapped out the amplifier with the eBayed one I got and both windows worked great for about two minutes. Just as I was about to shut the car off and call it a day, the passenger side stopped rolling up again.
So, now that I've replaced the window motor AND the amplifier, I'm kind of at a loss. First of all, is there anything else it could be? If not, it would seem that one of the parts I bought as a replacement is bad. Any idea which one for sure?
Thanks.
Shells is offline   Reply With Quote
