Old 11-12-2006, 11:46 PM   #1
Rogue240sx
Rogue240sx's Avatar
Rogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud ofRogue240sx has much to be proud of
Send a message via AIM to Rogue240sx
Audio: USAmps USA-1000x high end amplification
I just blew my engine so I'm selling off some of my older audio. First part out the door is this Great black USA-1000x. Not in show condition but runs awesome. Never saw over 1/4 turn on the gain since I've had it. I was running 2 10" Alpine Type R (older style) in a sealed box and it sounded great. I had the car metered at 139.7db with this amp which isn't bad for these 10's in a sealed box. $400 obro(don't be afraid to ask). pics soon to come.
here's the specs:
USA-1000X Only @12v
Two Ohm Stable
300 Watts x 2 into 4 Ohms
400 Watts x 2 into 3 Ohms
500 Watts x 2 into 2 Ohms
1000 Watts Bridged into 4 Ohms
Available in Black or Chrome
Two Channel Class AB Amplifier
Total Power Output: 1000 Watts RMS
THD at Rated Power: <0.006%
Stereo Separation: >98dB
Signal/Noise Ratio: 105dBA
Frequency Response: 5Hz-50KHz
Fuse Rating: 135 Amps
Dimensions: (Including Terminals)
62mm / 2.44in High
229mm / 9.0in Wide
451mm / 17.75in Long
Weight: 4.76kg / 10.5lb
Variable 24dB Low-Pass Active Crossover
There's not enough hours in the day.
Rogue240sx is offline   Reply With Quote
