Old 10-01-2006, 09:16 AM   #1
kernel
Trader Rating: (28)
kernel is an unknown quantity at this point
Feedback Score: 28 reviews
Boost Issues, need help
When my engine come to boost, it goes VERY LEAN and make backfire like a automatic machine gun...
it happened on the highway when i wanted to snap it to pass someone. i heard a loud pop coming from the front then the car feel like all the power were gone when i come to boost.
i have checked all the coupler, everything is fine. I didnt changed the z32 fuel filter but i have checked it, it look fine. Same thing with the fuel filter in the fuel tank on the pump. The pump has good 12v, it wired on a relay directly to trunk mounted battery. its a walbro 255lph.
for my fuel mangement, i have an safc2 with 740cc & z32 maf. As for the maf, its not defect. I do have a greddy fmic and all the piping, coupler are fine.
i do have too a nismo fpr and the "vacuum" part can spin freely, i dont know if it could be defect and do not hold the pressure good?
The engine running perfectly without running boost...i have EBC with all setting to hold boost at 0 psi and i can run with it, np.
well, id like to know if someone has already got this problem and know where to look to get it fixed.
sry for my bad english and you guys can ask me any question so we can find out my problem, im looking on the board often, thanks.
kernel is offline   Reply With Quote
Old 10-01-2006, 12:59 PM   #2
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
it sounds like a tuning problem, since your using such big injectors, you should really be using a better form of fuel management
Slip Gypsies Blog
not sure if you realize this
Old 10-01-2006, 01:19 PM   #3
NemeGuero
No more nissan.
NemeGuero's Avatar
Word.. SAFCs are only good to +-50% of stock injector sizes..
SR = 1.5 X 370 = 555cc
KA = 1.5 X 270 = 405cc
Old 10-01-2006, 01:52 PM   #4
kernel
Trader Rating: (28)
im running these injectors with safc2 and maf z32 since the beginning of summer and i have never got that problem before
my tune was ok and had no problem at all running 15 psi..i have AEM wideband in my car.
Old 10-06-2006, 06:49 PM   #5
steve shadows
steve shadows's Avatar
Please specify.
Like Me on FaceBook !
Old 10-07-2006, 06:35 PM   #6
kernel
Trader Rating: (28)
well, i have solved my issue, it was a bad coilpack that wasnt firing enough good under pressure.
about my fpr, the part that has the vacuum port spin freely, there already thread about that on the forums i think, i know someone else had the same issue with it.
Old 10-10-2006, 04:59 PM   #7
johngriff
johngriff's Avatar
If the FPR has an obvious vacum leak, it should be replaced immediately.
Pictures?
John
[email protected]
