Old 10-22-2006, 12:20 PM   #1
TurbLu
TurbLu is making his/her stupidity well-knownTurbLu is making his/her stupidity well-knownTurbLu is making his/her stupidity well-known
Fresh Sr20det swap wont start - cranks and cranks...
Ok guys,
My Sr swap is in and wired up. Ive checked the wiring and it all *seems* correct. The power wire sending power to the coilpack plug (Blue/Red) is getting power. Now how do I check to make sure I AM getting spark? Could it be my plugs? I didnt change the plugs in the engine as my autozone here does not carry those NGK plugs. Is there an equivelant plug? They are nice and black and all fouled up, could this be the problem?
1. How do I check for spark if the Engine is not running. (can I do it the old fashion way with a screw driver in the tip of the coilpack?)
2. Is there an equivelant plug to the NGK I can pick up at the AutoZone?
TurbLu is offline   Reply With Quote
Old 10-22-2006, 12:39 PM   #2
LookOut Nick
LookOut Nick's Avatar
LookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond repute
1 Yes
2 Heat Range 6 NGK plugs were available at my local Napa, Id check their.
Team Pterodactyl
LookOut Nick is offline   Reply With Quote
Old 10-22-2006, 01:29 PM   #3
slow92_s13
slow92_s13's Avatar
slow92_s13 is an unknown quantity at this point
Send a message via AIM to slow92_s13 Send a message via Yahoo to slow92_s13
i use bkr7e's....try that, they are easy to get. have you check all your connections and stuff yet? oh and check ur fuel lines, not saying ur dumb...but its a common problem of hooking up the fuel lines backwards lol.
slow92_s13 is offline   Reply With Quote
Old 10-22-2006, 02:31 PM   #4
TurbLu
Ok... So heres my update:
I have no spark coming from the coilpacks.
Fuel lines ae hooked up ok.
I have my wires done accordingly to all the guides online. Only 2 wires are even Ignition Related in all the tuturiols. Ive tested them with a test light and they are showing to have power. Now How do I check the ignitor via Voltmeter to make sure the ECU is sending the pulses?
Old 10-22-2006, 04:09 PM   #5
TurbLu
bump for help... its sunday and I'd love to hear this engine start...
Old 10-22-2006, 05:06 PM   #6
Chernobyl
Chernobyl's Avatar
Chernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond repute
turn your CAS 180 degrees
turn key
hear engine run
Chernobyl is offline   Reply With Quote
Old 10-22-2006, 05:17 PM   #7
misfitsfreak81
misfitsfreak81's Avatar
misfitsfreak81 is an unknown quantity at this point
check your CAS for any damage. look at it VERY CLOSELY, even the smallest ding or crack will screw it up. just pull the cover off to check it. you can take a paper clip and back-probe the wires on the ignitor chip. DO NOT EVER pierce the plastic on the wires, always backprobe. im sure that the spec. voltage will be in the FSM, i dont remember it right off hand. you can also get a plug tester at any auto part store, i would recomend that over the screwdriver trick. the FSM has a great step by step procedure for checking the ignitor, CAS, and the ECU as well as how to check continuity for all the aformentioned. oh also if its your cas you most likely wont get any firing of the injectors either, be sure to check those as well. hope this all helps. keep us updated as to what you find.
mike
misfitsfreak81 is offline   Reply With Quote
Old 10-22-2006, 06:54 PM   #8
TurbLu
turn key
hear engine run
CAS wont cause a no spark issue which is what I have for sure now. So my next step is to find the fsm for the SR20det.
Old 10-22-2006, 09:01 PM   #9
TurbLu
CAS is fine. But I do not know how to trouble shoot the Ignitor chip via the FSM (I cant find it).
How many engine grounds should I have on this swap? I only have 1 hooked up to the intake manifold. Is there anymore. What about the one on the back of the block behind the valve cover?
Old 10-22-2006, 11:11 PM   #10
mandoz85
mandoz85 will become famous soon enoughmandoz85 will become famous soon enoughmandoz85 will become famous soon enoughmandoz85 will become famous soon enough
what number Is on Your ECU, you might have the wrong one or a bad ecu.
Also you can get NGK spark plugs at Meyers, they have them in stock.
mandoz85 is offline   Reply With Quote
Old 10-22-2006, 11:24 PM   #11
TurbLu
ECU 62 - says its correct via the fact...
Update: I think my dash wiring may be off as when I pull the key out the red lights (2 on the right side) on the dash stay on for a few minutes before shutting off. Is this related to the dash harness conversion or the Ka harness conversion behind the passenger headlight?
Old 10-23-2006, 09:51 AM   #12
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
the ignitor/power transitor chip test is located in Engine Control page 202....or atleast it is in my FSM that i got from camel-towing.com...hope that helps.
ladiesman8527 is offline   Reply With Quote
Old 10-23-2006, 10:32 AM   #13
TurbLu
thanks... now that its warm enough to go outside Im going to start double checking all my wiring and make sure I dont have back-power going through my grounds...
Old 10-23-2006, 10:41 AM   #14
broken240sx
broken240sx is on the path to ruinbroken240sx is on the path to ruin
there is an important ground at the back of the valve cover, it isn't part of the removable harness, folow the coilpack wires back and you'll find it, if you didn't connect that ground you won't get spark
broken240sx is offline   Reply With Quote
