Old 11-06-2006, 05:40 PM   #1
wantboost
wantboost's Avatar
wantboost is an unknown quantity at this point
Send a message via AIM to wantboost Send a message via Yahoo to wantboost
Where to tap sr20 for egt (searched)
ok, my search came up with either 2nd or 3rd (because they run the hottest) then 4th (closest to firewall)
i really want to run it on the runner of the hottest cylinder.. any ideas
wantboost is offline   Reply With Quote
Old 11-06-2006, 06:53 PM   #2
IngS14
IngS14's Avatar
IngS14 is making a name for him/her selfIngS14 is making a name for him/her self
Send a message via AIM to IngS14
i used had my EGT tap onto #4 runner then i tap onto #1 becasue ive found out the #1 always ran hot and leanier.but i suggest you get a wideband O2 to get the exactly & as possible reading on airfuel maxture.the wideband is definately needed and will help you when you tune your ecu with safc (most ppl had) on the street or dynojet.
IngS14 is offline   Reply With Quote
Old 11-06-2006, 07:36 PM   #3
wantboost
wantboost's Avatar
i already have a wideband.
it doesnt tell me which cylinder is hottest
Old 11-06-2006, 11:22 PM   #4
silverarrow27
silverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud of
I tapped it at the collector where all four met.
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd
silverarrow27 is offline   Reply With Quote
Old 11-06-2006, 11:57 PM   #5
IngS14
IngS14's Avatar
get 3 more EGT tap 1 to each runner and find out which one is hottest then sell 3 other EGT.is that a good idea or what mang?lol.....thats the only way you can find out,old skool way!
Old 11-09-2006, 12:14 AM   #6
GSXRJJordan
GSXRJJordan's Avatar
most pre-tapped manfolds come with the 4th runner tapped. Doesn't tell you which is hottest though. Ideally you want a reading for each cylinder and some ITBs to tune each cylinder individually, but eh, it's a lot of work.
I'd say tap the 4th.
Old 11-09-2006, 09:20 AM   #7
projectRDM
projectRDM's Avatar
Exhaust housing for the turbo. It's not the hottest, but it's the most accurate.
Old 11-09-2006, 11:13 AM   #8
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I tapped mine in the collector but ideally your supposed to tap the hottest cylinder but like said, theres no easy way of telling which. Ive been told if your not sure, tap the cylinder thats closes to the FPR. If your car runs lean due to fuel issue, its the furthest cylinder and closes to the FPR that will have the least amount of fuel causing it to lean out. For SRs, the FPR is up front so #1 will lean out. For KA, the FPR is in the rear so #4 will lean out.
CLICK HERE!!!
