Power Steering woes
OK so after the whole head gasket install. My power steering has not worked since day one of the 2JZ install . I have ignored it and just driven it like that. So today after the car decided to follow a groove in the road and almost put me in the wall i decided its time to fix it. Now I have removed the pump and replaced the pump. Still no Power Steering. I replaced the reservoir and its still doesn't work. I replaced the return hose form the frame rail to the pump and still no power steering. I am only to believe that my rack is FUBAR'd I have even tried to bleed the powersteering pump a few times. Nothing. The fluid does not over boil and the pump does not make any nosie. So next I need to find the drain for the rack and drain it fully run compressed air through it and and make sure its not clogged. Then go from there. It doesn't leak and it seems to be cycling the fluid from out of the reservoir and back into it. It just does not work. I am going nuts about it. Any help would be appreciated. Any ideas what to look for. I did slightly bend one of my lines out of the way for the intercooler but its not kinked just moved slightly. Like 1cm. to the outside which means its straightened not pinched.
UGR.....SOMETHING WICKED THIS WAY COMES....
