Old 03-31-2008, 03:40 PM   #1
whosaidthenword
whosaidthenword is a jewel in the roughwhosaidthenword is a jewel in the roughwhosaidthenword is a jewel in the roughwhosaidthenword is a jewel in the roughwhosaidthenword is a jewel in the roughwhosaidthenword is a jewel in the roughwhosaidthenword is a jewel in the rough
Send a message via AIM to whosaidthenword
How do u check the oil pressure
i just got a 240sx and i have that rattling noise coming from the timing chain problem. i was just wondering how would i check the oil pressure before i do anything. thanks. and could using different oil fix the rattling problem without even removing the guides?
whosaidthenword is offline   Reply With Quote
Old 03-31-2008, 03:44 PM   #2
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
oil pressure isn't really a matter of "checking"...it's an issue of monitoring it to prevent loss of lubrication making engine go boom. Get an aftermarket oil pressure gauge. Then, probably the easiest way to hook it up would be to get an oil filter "sandwich" adapter which is a plate that screws in between the block and your oil filter (making a sandwich...get it?!?! lol). Screw in the sensor, plug it into the gauge, and voila!!
96Turbo is offline   Reply With Quote
Old 03-31-2008, 03:53 PM   #3
whosaidthenword
alrite thanks. because i am having that marble in a can rattling noise coming from the chain hitting the guides. i am about to remove the 2 guides and clean the tensioner and see if it gets rid of the noise
Old 03-31-2008, 03:59 PM   #4
cronux
cronux's Avatar
cronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to all
do it. now. haha. mine made noise, and i neglected it. then the guide busted offf.
cronux is offline   Reply With Quote
Old 03-31-2008, 04:01 PM   #5
Clawhammer
Clawhammer is making a name for him/her selfClawhammer is making a name for him/her self
Send a message via AIM to Clawhammer
You can just unscrew the stock oil pressure sender and screw in your sensor. That's what I did, you don't need the dummy light on the dash if you have a gauge.
Clawhammer is offline   Reply With Quote
Old 03-31-2008, 06:58 PM   #6
undesiredshoe
undesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of light
Send a message via AIM to undesiredshoe
You just phuxed up your threads then son. Ka's and Sr's come with bspt threads that are close to the normal npt threads but they are a little different.
undesiredshoe is offline   Reply With Quote
Old 03-31-2008, 07:12 PM   #7
hijack3d
hijack3d's Avatar
hijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond repute
I'm surprised nobody else has said this (probably because it wasn't exactly your question), But removal of the timing chain guides can eliminate that "rattling in a can" noise that you're experiencing. Nissan has even regarded them as unnecessary.
Since you're new, here's a link to removing the guides.
Don't worry, it's legit: Review (Thanks Mike)
hijack3d is offline   Reply With Quote
Old 03-31-2008, 09:30 PM   #8
cronux
cronux's Avatar
he already said that he was going to.
Old 03-31-2008, 10:12 PM   #9
Clawhammer
Incorrect. I bet you a dollar my Greddy oil pressure sensor has the same 1/8" BSPT. paypal to: [email]
Old 03-31-2008, 10:25 PM   #10
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
or you can tee into the turbo lines if they are after market. install a line from the sending unit to the fitting you add on your line.
do not directly mount the sending unit to the fitting without the line even if it fits and works. the sending unit can break off and be the cause of losing oil and starving the engine wouldn't that be an ironic bitch
bigOdom1 is offline   Reply With Quote
