Old 12-29-2006, 05:52 PM   #1
Blackhat
Blackhat is an unknown quantity at this point
SR weight
Anyone have a weight of just the SR20DET? Not including the transmission. I saw somewhere someone was saying 330lbs but that didn't sound right to me. Also, does anyone have the weight of the KA? Also not including transmission. I weighed one of mine but it was the block only with not internals. That came out to 100lbs.
Actually, if someone has the weight of either with the transmission that would work too.
Blackhat is offline   Reply With Quote
Old 12-29-2006, 05:56 PM   #2
Eddie@Performance
Eddie@Performance's Avatar
Eddie@Performance is making a name for him/her selfEddie@Performance is making a name for him/her self
Send a message via AIM to Eddie@Performance
I have read somewhere that a stock KA weighs about 450~ish lbs. So 3 something for a SR seems about right as i heard the SR are 40-50lbs lighter then the KA.
Eddie@Performance is offline   Reply With Quote
Old 12-29-2006, 05:57 PM   #3
Wykydtron
Wykydtron's Avatar
Wykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really nice
the SR20DET weighs 490 lbs. The KA24E weighs 493 lbs.
Search Next Time Pls,
K, thanks
@schassis.eddi
Wykydtron is offline   Reply With Quote
Old 12-29-2006, 06:02 PM   #4
Blackhat
That's with tranny on both of those?
Old 12-29-2006, 06:02 PM   #5
Eddie@Performance
K, thanks
Whoa....i thought there was more then 3 lbs difference considering we are comparing a Alloy block versus Iron, which i would think is more then 3lbs weight difference no ? I did a serach and this is where i read this: from http://www.drifting.com/forums/archi...hp/t-2082.html
[ Engine weight engine weights engine weigh transmission weight transmission weights ]
Without transmisison (figure +100-150lbs)
A12 87 kg 192 lbs
A14 93 kg 205 lbs
L18 118 kg 260 lbs
CA18ET 118 kg 260 lbs
QR25DE 121 kg 267 lbs
CA18DET 128 kg 282 lbs
SR20DE 139 kg 306 lbs
SR20DET 149 kg 328 lbs
FJ20ET 166 kg 366 lbs (205 hp)
KA24DE 167 kg 368 lbs (est)
the SR20DET weights 490lbs with a trans according to that info.
Old 12-29-2006, 06:05 PM   #6
Blackhat
I'd rather not go by guessing. I've searched everywhere and all I get is statements saying plus or minus so many pounds to how much this engine weighs... I beginning to believe no one has weighed them.
Old 12-29-2006, 06:08 PM   #7
Wykydtron
Wykydtron's Avatar
estimated w/o transmission
The SR20DET has an aluminum block, the KA24 has iron.
But why do they weigh nearly the same?
The SR20DET has a turbocharger and intercooler piping, the KA doesn't. A 240 with a KA-T is pretty front heavy X_X
Sure, its logical to think the SR weights lighter (a lil bit), but it would weight a lot less without the turbocharger.
The SR and KAe was weighed during this project:
http://www.sportcompactcarweb.com/te...via/index.html
@schassis.eddi
Old 12-29-2006, 06:21 PM   #8
Blackhat
Thanks for the info, that is interesting.
How much does the standard turbo equip weigh on a SR?
I find it interesting that technically speaking the stock SR has more front end weight than the stock KA, due to more of the weight being farther forward than the KA (IC & piping).
**edit**
Doh, didn't see where you agreed with the other wieghts for engine only, which would mean about 40lbs for turbo equip.
