Old 07-11-2002, 03:09 PM   #1
shinigami24
shinigami24 is an unknown quantity at this point
hi guys, there is some noise coming from my engine, it starts at around 2.5k to 3k rpm and it keeps going, its a rattling sound, anyone got any idea what it is, my dad thinks its the timing chain, please help me out, this thing is annoying me
shinigami24 is offline   Reply With Quote
Old 07-11-2002, 03:36 PM   #2
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
prob the timing chain if its a SOHC. How many miles you have on the engine? My timing chain rattles all the time now. I just got all the parts for  220$ and im going to fix it myself. I might document it with some pictures and do a writeup for it, ill let yaz know.
West - Zilvia.net - Toyobaru.net - NapkinSketch.com
West is offline   Reply With Quote
Old 07-11-2002, 03:47 PM   #3
shinigami24
i bought the car with knocking engine, it had 114k, then i replaced it with another one that has 89k miles
Old 07-11-2002, 08:49 PM   #4
aqwkmf
aqwkmf is an unknown quantity at this point
i have 101000 miles...should i be worrying about my chain...i dont have any rattles.........yet <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/crazy.gif" border="0" valign="absmiddle" alt=':crazy:'>
aqwkmf is offline   Reply With Quote
Old 07-11-2002, 09:19 PM   #5
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
well i replaced my t chain myself also but i still have a rattle it sounds like i have bad crank bearings is what another tech at work said but i dont feel like messing with it at all till it blows <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''> sr after that. see if you have good compression it may be piston slap or ur rings can be worn are u burning oil?
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
Old 07-11-2002, 09:44 PM   #6
SR20Fastback
SR20Fastback is an unknown quantity at this point
Send a message via AIM to SR20Fastback
If the rings were worn, would it really make a noise?
Fodive STILL blows goats, I have proof.
SR20Fastback is offline   Reply With Quote
Old 07-15-2002, 09:03 AM   #7
Rownan
Rownan is an unknown quantity at this point
Send a message via AIM to Rownan
Does it rattle during startup? &nbsp;If so, it's probably the timing chain. &nbsp;You have a SOHC 240 so if it is higher mileage and hasn't had the timing chain job before you should probably replace it anyway...
Or it could be a heat shield.. &nbsp;When I had my 1990 S13 it had a metallic rattle right around 2700rpms.. &nbsp;I found it to be the heat shield on the bottom of the exhaust manifold where the two pipes combine. &nbsp;It's probably hanging by a single loose bolt like mine was and all the rest of the bolts have probably rusted off. &nbsp;Check into that. &nbsp;It's a common problem on S13s.
Tim
Rownan is offline   Reply With Quote
Old 07-16-2002, 09:30 PM   #8
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
Your timing chain should rattle even beyond just 3K, if it's the timing chain.
Your heat shields should rattle beyond 3K as well. The higher you rev, the more they will rattle.
Why don't you check the simple shit first?
S13Grl is offline   Reply With Quote
