Old 07-18-2002, 02:34 AM   #1
240Stilo
Junkie
240Stilo's Avatar
240Stilo is an unknown quantity at this point
Send a message via AIM to 240Stilo
Anyone ever experience an oil leak with their ka24de? I got an oil leak and i wanna take care of that before i get too excited over buying things to make my car go faster. My best guess was that the seal around the oil pan is messed up because the oil pan is all covered with oil.
-Juan
240Stilo is offline   Reply With Quote
Old 07-18-2002, 03:29 AM   #2
Yosho
Yosho is an unknown quantity at this point
Hmmm it could be, but it could be a lot of other things leaking instead.
Check the Oil Pressure Switch/Sensor (they fail a lot on Nissans) and the Front Crank Seal.
- Yosho
'93 Nissan 2000 GSR
'96 200SX SE-R
'00 Civic Si (For Sale)
Yosho is offline   Reply With Quote
Old 07-18-2002, 04:59 AM   #3
-E-
-E-'s Avatar
-E- is an unknown quantity at this point
I had the same prob with my 95 first it was the oil pan gasket I got that fixed but it was still leaking oil,it turned out to be the seal between the engine and tranny
-E- is offline   Reply With Quote
Old 07-18-2002, 08:05 AM   #4
sykikchimp
WOW addicted
sykikchimp's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (EONE914 @ July 18 2002,06:59)</td></tr><tr><td id="QUOTE">I had the same prob with my 95 first it was the oil pan gasket I got that fixed but it was still leaking oil,it turned out to be the seal between the engine and tranny</td></tr></table><span id='postcolor'>
do you mean the rear crank seal?
Old 07-18-2002, 09:00 AM   #5
Natty
Natty is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sykikchimp @ July 17 2002,10:05)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (EONE914 @ July 18 2002,06:59)</td></tr><tr><td id="QUOTE">I had the same prob with my 95 first it was the oil pan gasket I got that fixed but it was still leaking oil,it turned out to be the seal between the engine and tranny</td></tr></table><span id='postcolor'>
do you mean the rear crank seal?</td></tr></table><span id='postcolor'>
Thats what it sounds like. When I had my clutch put in, the mechanic never recommended getting a new rear main crank seal. My other mechanic then recommened the first one be shot &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/lookaround.gif" border="0" valign="absmiddle" alt=':look:'>
It's a cheap gasket, but a pain to replace.
Jeff
1991 White 240sx Fastback LE, rusty spoiler, weak driveshaft, exhaust rattle....
Rattles are just your cars way of saying 'I love you.'
Natty is offline   Reply With Quote
Old 07-18-2002, 11:42 PM   #6
240Stilo
Junkie
240Stilo's Avatar
EONE, how did the bottom of your engine look when it was leaking?
-Juan
Old 07-19-2002, 12:11 AM   #7
-E-
-E-'s Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (240Stilo @ July 18 2002,01:42)</td></tr><tr><td id="QUOTE">EONE, how did the bottom of your engine look when it was leaking?</td></tr></table><span id='postcolor'>
it kinda clean except for some oil spots from where it was leaking
Old 07-19-2002, 12:14 AM   #8
240Stilo
Junkie
240Stilo's Avatar
Oh, because my oil pan looks like it was dipped into a bucket of oil.
-Juan
Old 07-19-2002, 12:16 AM   #9
240Stilo
Junkie
240Stilo's Avatar
Does anyone have experience with taking off the oil pan? I'd like a few pointers because i'm gonna plan on putting a new seal on it. I thought it was a gasket so i went to the nissan dealer to ask about it and the guy there said that the KA24DE has a silicone seal.
-Juan
Old 07-19-2002, 08:44 AM   #10
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
what yosho said would be the first things i would look at those are more problematic than a rear seal. next thing i would look at is the front cover.
but since you said your oil pan is soaked look at your crank seal and O.P.S.
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
Old 07-19-2002, 01:48 PM   #11
240Stilo
Junkie
240Stilo's Avatar
The crank seal is between the transmission and engine correct? And could it be possible that it's leaking from the lower pulley? because that was wet too.
-Juan
Old 07-20-2002, 12:49 AM   #12
camppain
camppain's Avatar
the crank seal is covered by the crank pulley. you must remove your belts the remove the pulley and you will see the crank seal. pry it out using a flat head screw driver and clean off hte area with some brake clean and put hte new one in using a rubber mallet till its flat with the surface. &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
im not good at explaining maybe someone can provide more info if mine is a lil confusing.
Old 07-20-2002, 01:01 AM   #13
Lyger
Lyger is an unknown quantity at this point
I have the same problem with my 95 240, but it would only leak when its on a hill like a driveway. When its on a flat surface it won't leak anymore. How much would it be to replace it.
Lyger is offline   Reply With Quote
Old 07-20-2002, 01:26 AM   #14
misnomer
misnomer's Avatar
First task in troubleshooting anything is finding out exactly what your problem is. See where it's leaking from, then fix it. There aren't too many places for oil to leak from: valve cover, front main seal, rear main seal, and oil pan are the main ones. I don't know about the oil pressure sensor, but I'll need to take a look at that to fix my own leak :-)
Old 07-20-2002, 01:21 PM   #15
240Stilo
Junkie
240Stilo's Avatar
Ok, i understood what camppain said. Only thing to do now is to do it. I'll probably start off putting a new layer of silicone for the oil pan and i might as well put in a new crank seal.
-Juan
Old 07-20-2002, 04:11 PM   #16
Yosho
In general, everything that leaks flows down and back on an engine. &nbsp;So if your Front Crank Seal is leaking, it'll just leak all over the oil pan and look like the oil pan is leaking. &nbsp; &nbsp;Same is true of the front cover or even valve covers. &nbsp;You have to trace the leak back to it's source. &nbsp;This isn't always possible on a dirty engine. &nbsp;Nissan hit's this hard in their tech training material. &nbsp;It's called Masking... where one problem looks like something else and in fact, may be several problems.
Before you make any repairs, I'd suggest you fully clean the engine off... spending an hour cleaning the engine is better than replacing parts that don't need replacement yet. &nbsp;Not only will you find the true cause of your leak, but you may find other things you'll need to replace and if nothing else, you'll have a nice clean engine and be able to notice when something new starts to leak.
You can use an engine degreaser... that's probably the easiest. &nbsp;When I worked at a Nissan dealership, we all used brake cleaner to clean off all that garbage... but we had unlimited amounts of it and it wasn't used as a spray (like you'll get in a can at an Auto Parts store) so you'll probably want to stick with the normal degreasers.
- Yosho
'93 Nissan 2000 GSR
'96 200SX SE-R
Old 07-21-2002, 01:42 PM   #17
240Stilo
Junkie
240Stilo's Avatar
I already did clean it in hopes to trace the source but the only problem was that it was very hard to clean off all the oil from the front of the oil pan. I assume the reason for this is that the front crank is what is leaking so more layers of oil were sticking to the front side of the oil pan. Another problem is i need an oil change soon so i'll try the front crank seal and hope for the best. Thanks all
-Juan
Old 07-21-2002, 08:37 PM   #18
Yosho
If you look up between the crank pully and the block you'll see the seal. &nbsp;If there's oil on the seal... if it's wet, then it's your front crank seal that's leaking. &nbsp;Without seeing the car, that would be my guess.
- Yosho
'93 Nissan 2000 GSR
'96 200SX SE-R
Old 07-23-2002, 01:03 AM   #19
240Stilo
Junkie
240Stilo's Avatar
How hard is it to change the seal myself? From what i've heard the biggest problem would be to make sure the timing is correct after i put the pulley back. Anyone have experience with changing the front crank seal?
-Juan
