Old 02-06-2002, 07:04 PM   #1
silvia lover
silvia lover's Avatar
silvia lover is an unknown quantity at this point
Is there any good suspension setup for a 91 240sx with  hicas on it? i would like to lower it about 1-1.5inch though. how much will that be. any advise.
silvia lover is offline   Reply With Quote
Old 02-07-2002, 12:14 AM   #2
tnord
tnord's Avatar
tnord is an unknown quantity at this point
go with the same setup i have, it's cheap and effective
tnord is offline   Reply With Quote
Old 02-07-2002, 12:23 AM   #3
Archangel
Archangel's Avatar
Archangel is an unknown quantity at this point
Send a message via AIM to Archangel
There are a lot of setups. Before we go any further, let me just say, that my suspension is bone stock (base model 98). However, there are a couple of ways to go.
One of the cheapest, easiest setups are lowering springs with some good aftermarket shocks. The other way to go is coil-overs. (Sorry if you already know this, but I wanted to explain if you didn't.) Coilovers are a spring/strut combination that replaces the springs and stuts, most coilovers are adjustable.
Lowering springs - Eibach makes good springs (<a href="http://www.eibach.com/index1.htm" target='_blank'>http://www.eibach.com/index1.htm</a>) they have a Pro-kit that lowers your car 1.8 in the front, and 1.6 in the back, which may be just about what you're looking for. Match that with some good shocks like Koni's for example (<a href="http://www.koni-na.com" target='_blank'>http://www.koni-na.com</a>). However there are alot of other lowering springs and shocks out there, these are just 2 of the more popular brands.
Coilovers are going to run you more $$$, but most of them are height, and stiffness adjustable, which can be very nice. There are a wide range of coilovers.
Teins - <a href="http://www.tein.com/products.html" target='_blank'>http://www.tein.com/products.html</a>
JIC - <a href="http://www.zielmotorsports.com/suspindex/suspindex.html" target='_blank'>http://www.zielmotorsports.com/suspindex/suspindex.html</a>
Apexi - <a href="http://www.apexi-usa.com/suspension.asp" target='_blank'>http://www.apexi-usa.com/suspension.asp</a>
Those are some of the nicest (most expensive). There are cheaper brands out there, but I can't think of any off hand.
Here's a good site to check out pricing on all of it. I'm not saying the pricing is the best, but it'll give you a good idea of pricing. <a href="http://www.wholehyper.com/index.html" target='_blank'>http://www.wholehyper.com/index.html</a>
Do a search on all the forums for supension, and you'll come up with a day's full of reading material on parts on brand comparisons.
Archangel is offline   Reply With Quote
