Old 02-01-2007, 10:47 AM   #1
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
cheap SR Ex. studs and turbo stud replacement with Toyota OEM.
Watsup everyone.. i work over at a toyota dealership as a parts guy and found which part numbers from toyota will work for the SR's exhaust manifold studs . these are not the exact studs. the first part going into the block is the same length and identical to ours. the part where the exhaust manifold sits is LONGER, so you can fit two nuts on there.. they are also crimped on the ends a bit so the chance of them loosening is next to zero. AKA you wont have to retighten your shit again, same for the 4 studs going from exhaust mani-turbo. they are also dirt cheap and you should be able to purchase everything i have listed for $40, unlike the expensive OEM nissan ones being sold everywhere.. very strong studs and nuts, our mechanics use them over and over again..i have these on my sr, along with a bunch of others at work on their sr's, they works great. i had a problem with my setup because the nuts would loosen up over time, i got sick of it and figured this stuff out. thanks to JIS hope this helps someone..if anyone else might want to match up a stud or anything let me know, ill see what i can do.
block to manifold (8)
90116-10017
stud nuts
94180-41000(8, or 16 for baller status :P)
studs for mani to turbo (4)
90116-08348
get nuts for these from Ace Hardware or something.. easily found.
-Bart
DJ_Sunrise is offline   Reply With Quote
