Old 02-04-2002, 07:16 PM   #1
blades
blades is an unknown quantity at this point
O.K. i get in my car and my clutch pedal is in the right spot about level with my brake pedal. when i use my clutch and remove my foot it does not come back all the way (about halfway) and if i put my foot under the pedal and lift it up it will come back and i can use 1 more time before i have to do the samething. so basically everytime i use my clutch i have to lift up on pedal before i use it again. the one good thing about it is that my clutch still seems to work fine, it grabs fine, my pedal is just screwd!! does anyone know what this is??do i just need to bleed it or adjust it somehow, or is it something like my slave/master cylinder?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'> please help!!thanks
blades is offline   Reply With Quote
Old 02-04-2002, 07:47 PM   #2
hookedup240
hookedup240's Avatar
hookedup240 is an unknown quantity at this point
Send a message via AIM to hookedup240
That happenes to me too, i got a 91 but the clutch still works fine i haven't tried messing with it at all, its been like that for a couple months
hookedup240 is offline   Reply With Quote
Old 02-04-2002, 08:03 PM   #3
240racer
240racer's Avatar
240racer is an unknown quantity at this point
I haven't bled the clutch on a 240, but when we bled the clutch on my friends eclipse, that was excatly what it was like. &nbsp;I had to sit in the car and pull the pedal back up everytime to pump the air out. &nbsp;I would assume that you might have a leak somewhere, look for fluid around the lines and stuff, then bleed the clutch. &nbsp;It should have a bleed nipple on the cylinder. &nbsp;Just keep bleeding untill the clutch feels good again. &nbsp;hope it works
240racer is offline   Reply With Quote
Old 02-04-2002, 09:58 PM   #4
blades
Can anyone out there give me detailed instructions on how to bleed my clutch???i did a search on it but could not find it. &nbsp;(90 s13 coupe) thanks
Old 02-05-2002, 09:30 AM   #5
blades
Please, someone must be able to explain in a little detail on how to bleed my clutch, i'm getting real sick of lifting my pedal up everytime i shift!!!
&nbsp;thanks
Old 02-05-2002, 10:28 AM   #6
drifterx
drifterx's Avatar
drifterx is an unknown quantity at this point
Send a message via ICQ to drifterx Send a message via AIM to drifterx
ohhh u know what.. that happened to me
i broke the clutch petal bracket
drifterx is offline   Reply With Quote
Old 02-05-2002, 07:54 PM   #7
MyFirst240SX
MyFirst240SX is an unknown quantity at this point
Hey my first intelligent and helpful thing about cars i can say. &nbsp;how to bleed a clutch. &nbsp;All u do is open then bleed valve on the slave under the car(i belive its attached the passager side of tranny or close). &nbsp;press the clutch up and down till its empty fill it up the clutch fluid. &nbsp;open the bleed valve. press the clutch. close bleed valve. &nbsp;bring up the clutch. &nbsp;Keep doing this untill you get pressure
MyFirst240SX is offline   Reply With Quote
