Old 02-15-2007, 01:17 AM   #1
NotoriouS14
NotoriouS14's Avatar
NotoriouS14 has a little shameless behavior in the past
s14 Clutch Feels Way To Soft..need Help!!!
hi their zilvia members..
maybe you guys can help me out.
a brand new stock clutch kit was put on today on my s14 and the clutch pedal when i push it down is really soft.
should i be feeling it that soft?if not maybe we can diagnose it.
input would be helpful.thanks.
NotoriouS14 is offline   Reply With Quote
Old 02-15-2007, 01:41 AM   #2
Shaminii
Shaminii's Avatar
Shaminii is just really niceShaminii is just really niceShaminii is just really niceShaminii is just really niceShaminii is just really niceShaminii is just really niceShaminii is just really niceShaminii is just really niceShaminii is just really niceShaminii is just really nice
Send a message via AIM to Shaminii
You probably need to bleed the clutch some more.
Shaminii is offline   Reply With Quote
Old 02-15-2007, 07:52 AM   #3
g6civcx
g6civcx's Avatar
http://www.zilvia.net/f/showthread.p...ht=taka+clutch
Old 02-15-2007, 07:57 AM   #4
AwhiteS13
AwhiteS13's Avatar
AwhiteS13 is an unknown quantity at this point
What kind of clutch? The duralast clutch i used was very soft, its just a cheap clutch, It was like 90$ at autozone, if thats your "oem" clutch then your sol.
AwhiteS13 is offline   Reply With Quote
Old 02-15-2007, 08:36 AM   #5
Dream240
Dream240's Avatar
Yeah I bought an exedy stage 1 street clutch, which is basically an OEM clutch, and despite the clutch line upgrades, my pedal is really easy. Not so much soft...but it's definitely bled and no air. The stock pressure plates I think are just naturally soft.
I would bleed the system a few more times and if it's still soft, but the pedal returns and the car shifts from gear to gear, then you should be good.
Old 02-15-2007, 08:44 AM   #6
g6civcx
g6civcx's Avatar
I have an unknown brand clutch and pressure plate. With new OEM master cylinder, Nismo slave cylinder, and Taka braided clutch line with no damper, the clutch effort is still soft. Sometimes I wish it was a little stiffer, but it works well enough.
Old 02-15-2007, 09:48 AM   #7
smurfgcr
smurfgcr is making a name for him/her selfsmurfgcr is making a name for him/her self
soft pedal isnt anything dangerous, it just doesnt feel as good. no worries about it though. if your pedal isnt returning all the way, thats when you should worry about air in the lines, or a smashed assist spring bushing.
smurfgcr is offline   Reply With Quote
Old 02-15-2007, 10:52 AM   #8
g6civcx
g6civcx's Avatar
I suppose you can swap in a stiffer return assist spring.
Old 02-15-2007, 11:58 AM   #9
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
My clutch is very soft as well, and I even used DOT 5 fluid, got rid of the dampener, and I'm running a braided line straight from master to slave.
Mine is soft because my cylinders leak, you should check your cylinders. Even if it's just slightly moist, it makes a big difference.
Old 02-15-2007, 04:21 PM   #10
kandyflip445
kandyflip445's Avatar
A mitty vac to bleed helped mine a LOT. Along with the stainless line from SPL. Bleeding normally was a lot more hassle and it didn't come out as good either.
My 240 vBgarage
