Old 02-22-2007, 11:43 AM   #1
bigfoot6913
bigfoot6913 is an unknown quantity at this point
Structural?
Im just curious if anyone can tell me if this piece is structural? I want to remove it for esthetic reasons only and will leave it in place if you all tell me Im dumb... Thanks alot
I will be installing a 4 point cage and a rear upper strut bar shortly
bigfoot6913 is offline   Reply With Quote
Old 02-22-2007, 11:53 AM   #2
IngS14
IngS14's Avatar
IngS14 is making a name for him/her selfIngS14 is making a name for him/her self
Send a message via AIM to IngS14
i think those are ok to removed if you planed on fabricate welding in a rollcage.
IngS14 is offline   Reply With Quote
Old 02-22-2007, 11:55 AM   #3
irax
irax's Avatar
I don't know but I would leave it
irax is offline   Reply With Quote
Old 02-22-2007, 11:57 AM   #4
Dream240
Dream240's Avatar
c'mon man you're not dumb.... don't be so hard on yourself.
It's actually for two purposes, rear seat support, and chassis support. If you're putting in a roll cage, strut bar I don't think removing these will matter.
You gonna cut em out or melt the welds?
Old 02-22-2007, 12:05 PM   #5
swiin2
swiin2 is an unknown quantity at this point
I would drill the welds and plug weld the holes.....
swiin2 is offline   Reply With Quote
Old 02-22-2007, 12:12 PM   #6
bigfoot6913
Hammer and chisel?
Old 02-22-2007, 12:14 PM   #7
bigfoot6913
but seriously, a mixture of blood, sweat, tears, hammers, chisels and grinders.
Maybe even an oxy-acetylene torch.. Im not exactly well equipped but I think I can track down a torch... I removed my battery tray with a pry bar so I think I can manage
Old 02-22-2007, 12:21 PM   #8
Dream240
Dream240's Avatar
I would use a die grinder and dremel for the tight spots. Then the dremel to smooth the edges.
Old 02-22-2007, 12:40 PM   #9
cdlong
those reinforce the shock towers. if you put in a cage and a triangulated strut bar you should be ok. a regular strut bar won't do much to compensate for removing those.
cdlong is offline   Reply With Quote
Old 02-22-2007, 03:33 PM   #10
projectRDM
projectRDM's Avatar
They don't brace very much, I've cut them out before with no ill effects. STB and cage will easily triple any integrity lost, go for it.
Old 02-22-2007, 03:37 PM   #11
bik
bik is a name known to allbik is a name known to allbik is a name known to allbik is a name known to allbik is a name known to allbik is a name known to allbik is a name known to allbik is a name known to allbik is a name known to allbik is a name known to allbik is a name known to all
Send a message via ICQ to bik
I remove those already... u need to drill the welds off... hamer and chisel will destroy your chasis trust me i try a couple of with that O_o
i have roll cage welded in the chasis and is fine, in fact is pretty rigid now O_o
bik is offline   Reply With Quote
Old 02-22-2007, 10:11 PM   #12
defiantmofo
defiantmofo is a well-known jackass
there are alot of spot welds on that thing. you can get a spot weld remover drill bit from most hardware stores. it will save you lots of time and effort. I took mine both out in like 2hrs.
defiantmofo is offline   Reply With Quote
Old 02-23-2007, 08:40 AM   #13
kansas240
kansas240's Avatar
kansas240 can only hope to improve
aesthetic. and a cut off wheel or angle grinder will come in handy, fine tooth sawzall is good to have. you can NEVER buy too many tools.
Don't hate me, just because I hate you.
kansas240 is offline   Reply With Quote
