Old 02-21-2007, 08:51 AM   #1
bigflip
bigflip is an unknown quantity at this point
Q for kts coilover owners!
I just got mine yesterday and bought it used.Since it did'nt come with a instructions,I just want to know how the adjustment works.Do you start with soft and then turn clockwise to hard or opposite?
I know i could play with it but this is just in case somebody would know.Thanks
Victor
bigflip is offline   Reply With Quote
Old 02-21-2007, 09:01 AM   #2
SimpleS14
SimpleS14's Avatar
clockwise to hard and it should click for each full turn
Goals are dreams with a deadline.
L.H.O.O.Q.
SimpleS14 is offline   Reply With Quote
Old 02-21-2007, 09:32 AM   #3
cdlong
either your coilovers are different than mine or my memory is terrible.
turn it all the way clockwise to go full soft. up to 15 clicks counter clockwise tightens them up. don't go too far, you can get more than 15 clicks if you try, but all you're doing is screwing it up inside.
cdlong is offline   Reply With Quote
Old 02-21-2007, 10:40 AM   #4
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
I think you have it backwards.
The little blue knob on the top of the coil says L (Light) Counter Clockwise H (Hard) Clockwise.
I think that's right I just put my coils to full stiff and I'm enjoying it.
Old 02-21-2007, 11:30 AM   #5
cdlong
could be, i haven't adjusted them in a while. i'll look at them tonight.
Old 02-21-2007, 11:00 PM   #6
!Zar!
!Zar!'s Avatar
Right is hard. But when you adjust them, make sure to screw them all the way clockwise. Then back them out from there. And make sure not to back out past the amount of clicks the shock is rated for. iirc it's 14 or 15 clicks.
Old 02-21-2007, 11:20 PM   #7
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
15 clicks mel
New Video
Buy my mounts!
Old 02-22-2007, 08:28 AM   #8
bigflip
thank you for all your help guys!Not a drifter but had any of you used this in scca?
Old 02-22-2007, 12:24 PM   #9
cdlong
i have, i love them. i got them to reduce body roll, add front camber adjustment, and add a little precision to the system. i also took the opportunity to add the aluminum z32 uprights. i was successful on all accounts so i'm happy. i have some crazy mid/late corner oversteer now but i think that's an alignment issue. i'm still dialing the suspension in, once it's done, i should have a pretty decent setup.
i won my class this past weekend so it can't be all bad (out of six). i usually place about halfway up. i won one other time but i was the only person in my class
Old 02-23-2007, 08:29 PM   #10
bigflip
nice,can you suggest how I should set the coils up?front/back how soft/hard?
Old 02-24-2007, 10:57 AM   #11
cdlong
from the softest setting, four clicks in front and three in the back. i haven't done enough tuning so don't take that as gospel. i softened up the back removed the rear sway bar and dropped the rear tire pressure in an attempt to add some more grip in the back. i think i need another half degree of camber also.
Old 02-24-2007, 12:24 PM   #12
KA24DESOneThree
KA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfection
You set them up according to your driving style. Everyone drives differently. You'll have to adjust them for different tracks and different surfaces. There is no one-size-fits-all setting.
KA24DESOneThree is offline   Reply With Quote
Old 02-25-2007, 02:49 AM   #13
bigflip
Ya, your right about setting it up according your driving style but it does'nt hurt to ask.At list I know of one setting I can try and see if it works,t.y cdlong!
